Key-in buzzer 70 Challenger #2245308
02/01/17 02:41 PM
02/01/17 02:41 PM
pa.
dan9 Offline OP
dan9  Offline OP
pa.
If I unplug the buzzer at the kick panel does it control anything else? Thank you
Re: Key-in buzzer 70 Challenger [Re: dan9] #2245319
02/01/17 02:58 PM
02/01/17 02:58 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Not that I have ever seen . . .
Re: Key-in buzzer 70 Challenger [Re: dan9] #2245330
02/01/17 03:17 PM
02/01/17 03:17 PM
Pittsburgh, PA
Slotts Offline
Slotts  Offline
Pittsburgh, PA
The 2983696 buzzer relay should be mounted on the lower dash frame by the glove box.
If you have the short factory diode adapter plugged into the T connector, top wiring circuits Q13A-18R & Q13B-18R and bottom circuits L6-18BK/Y* & L6A-18BK/Y*, the parking lights or parking light and headlights on with key removed will also trigger the buzzer relay, referred to as the Headlight Warning Buzzer, in the FSM.
Re: Key-in buzzer 70 Challenger [Re: Slotts] #2245811
02/02/17 11:21 AM
02/02/17 11:21 AM
moparx Online content
moparx  Online Content
those buzzers make great electrical diagnostic tools, so don't throw 'em away ! i have several made up with varying length leads. they work as a great audible device when working alone, as i do most of the time.
beer
Re: Key-in buzzer 70 Challenger [Re: moparx] #2246205
02/02/17 11:39 PM
02/02/17 11:39 PM
IN
ahy Offline
ahy  Offline
IN
Mine is un-plugged (for a reason) and no issues.
Reason is it was causing a no-start condition with my EFI car. The factory relay/diode was failing and sending a small current back through the ignition circuit. The current was enough to confuse the EFI box but not turn it on. Result was no start. Troubleshooting was not easy.
The key on buzzer was cute... but I do not miss it and my car starts. On a factory setup, the same problem would likely cause a battery drain problem.
Re: Key-in buzzer 70 Challenger [Re: dan9] #2246624
02/03/17 05:05 PM
02/03/17 05:05 PM
pa.
dan9 Offline OP
dan9  Offline OP
pa.
Thank you all for the responses. The buzzer was annoying while I was working on the heater wiring so I unplugged it. I will plug it back in when I'm done and just be happy it works. I hadn't thought about the lights on warning. Thanks again. Dan
