highest vin conv. barracuda #2244066
01/30/17 04:57 PM
01/30/17 04:57 PM
Ontario, Canada
GVH Offline OP
GVH  Offline OP
Ontario, Canada
Seeing the discussion on last Hemi's built .What is the highest vin for a conv. Barracuda or cuda built and date on body tag . Just curious supposed to stay inside damn bug.
my vin is BH27G1B429165 june 14 th 1971 Thanks
Re: highest vin conv. barracuda [Re: GVH] #2244459
01/31/17 01:45 AM
01/31/17 01:45 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I don't have as much '71 info organized as '70, but your Barracuda would be the latest '71 E-body convertible I know of
the latest Challenger I have info on is: JH27G1B426814 - "SCHEDULED" 6/09
Re: highest vin conv. barracuda [Re: GVH] #2244478
01/31/17 02:17 AM
01/31/17 02:17 AM
Chicago Blackhawks
hemicar1971 Online content
hemicar1971  Online Content
Chicago Blackhawks
Maybe Gerry if Ola lands his 767 he can chime in with the last Number in his Registry. I will look up numbers and see if I have a Serial number higher than yours but I would not likely have a build date or any other information.
1971 HEMI E BODY REGISTRY
Re: highest vin conv. barracuda [Re: GVH] #2244482
01/31/17 02:25 AM
01/31/17 02:25 AM
Great White North
Furyman Offline
Furyman  Offline
Great White North
71 vins run well into the 452000 range. Highest one Ive seen is BH27G1B438314 and there probably lots higher.
"Long Live Mopars"
Re: highest vin conv. barracuda [Re: GVH] #2244484
01/31/17 02:27 AM
01/31/17 02:27 AM
Chicago Blackhawks
Chicago Blackhawks
438--- 622 seems to be a popular date to sched. a Plymouth Convertible E Body to be built. Know of 4 with this date and I do not collect this stuff Ola is still the one to talk to.
Re: highest vin conv. barracuda [Re: GVH] #2244488
01/31/17 02:30 AM
01/31/17 02:30 AM
Chicago Blackhawks
Chicago Blackhawks
Furyman do you have many BCSheets of 1971 Challengers and Barracudas from May 20 to the end of production. Just the top line of the broadcast sheet has all that Dan or I would need for a bigger comparison.
Re: highest vin conv. barracuda [Re: GVH] #2244789
01/31/17 04:56 PM
01/31/17 04:56 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
1B438390 if my memory serves me correctly.
I will research my data base this week.
yes hemicar1971, I'm back from Asia flying my Boeing 777 around the world. Lol
Ola
1970 `cuda340 convertible 4-speed Rallye Red with Red interior
cudaized.com
1970-71 Plymouth and Dodge E-Body Convertible Registry
ebodyconvertibleregistry.com
Re: highest vin conv. barracuda [Re: cudaized] #2244823
01/31/17 05:48 PM
01/31/17 05:48 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Must be nice to have your own Boeing 777 and fly around the world on a whim
All I have is a glider
Stop and pick Kevin and I up sometime for a spin grin
I'll be the guy in the terminal reading your new book up
Re: highest vin conv. barracuda [Re: GVH] #2244854
01/31/17 06:38 PM
01/31/17 06:38 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
1971 Hamtramck VINs run at least into the 494xxx range.
It would take a lot of documentation to prove which of any model was actually built last, such as actual plant build records.
Re: highest vin conv. barracuda [Re: GVH] #2245449
02/01/17 06:43 PM
02/01/17 06:43 PM
Chicago Blackhawks
Chicago Blackhawks
Yes next to impossible is correct. Just want to get some ball park information put together. Like to see some more broadcast sheets from 395000 and up for the E Body build in May, June and July of 1971. I started trying to figure out the date of body panels, bumpers and other things on the 1971 to the 1972 build changes. Came up with some close numbers but it is never 100 percent on and exact Vehicle. I have never seen any information on Breaking Points on any of these changes. I use to go out in the Plant and stand by the Vehicles were I worked and write down the Sequence Number of the first Vehicle that got the new part. VIN has nothing to do with the part there is a Computer list of how thing went down the line and this number is the breaking point for the list. The VINS do not run in sequence so you need the master Sequence build to know were your vehicle stands with a change. Even then you have to know if a plant ca pull a build off the line and put it back in a different sequence. If Chrysler kept this information it is now recycled many times or burnt in one of the Plants Power Houses.
Re: highest vin conv. barracuda [Re: cudaized] #2270163
03/15/17 08:24 PM
03/15/17 08:24 PM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
The highest that I have personally seen for what it is worth is BS27 H1B 438332 built 6/22/1971
MMC/ ICCA Detroit. The Motor City or where ever there is Mopars
Re: highest vin conv. barracuda [Re: MMC Detroit] #2270165
03/15/17 08:26 PM
03/15/17 08:26 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Can you prove it was built that day?
Re: highest vin conv. barracuda [Re: Alaskan_TA] #2271422
03/17/17 10:24 PM
03/17/17 10:24 PM
Great White North
Furyman Offline
Furyman  Offline
Great White North
Can you prove it wasn't ? tsk
"Long Live Mopars"
Re: highest vin conv. barracuda [Re: Furyman] #2271433
03/17/17 10:46 PM
03/17/17 10:46 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Nope.
No more so than anyone can prove it was I suspect?
Big claim to make, so it was (and is) a serious question.
If proof of actual build dates exist, we would all love to know! wave
Up until the the MDH door sticker codes reflecting the final build data came to be of course.
Different story after that.
Re: highest vin conv. barracuda [Re: Alaskan_TA] #2271683
03/18/17 12:06 PM
03/18/17 12:06 PM
WV
Little Detroit Offline
WV
do you mean the "compliance decal"? That has nothing to do with the build date directly, just informing the Public that the vehicle was built to the MOTOR VEHICLE SAFTEY STANDARDS in effect on the date shown above?
Re: highest vin conv. barracuda [Re: Little Detroit] #2271872
03/18/17 05:26 PM
03/18/17 05:26 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
For anyone not yet aware of the MDH code that started fairly late in the 1972 model year, there is a two page TSB that explains it at http://www.hamtramck-historical.com/images/TSBs/1972/25-08-72D%20p1.jpg
http://www.hamtramck-historical.com/images/TSBs/1972/25-08-72D%20p2.jpg
Re: highest vin conv. barracuda [Re: Alaskan_TA] #2272020
03/18/17 09:53 PM
03/18/17 09:53 PM
WV
WV
Please stop with the smoke screens, the subject line was about 1971 barracuda's. 1970 was the first model year "required" to have the Compliance Decal. Please take note of the date of your posted "document", If I read it correctly it is dated 1972. The First "compliance decal" was first used on some but not all Daytona's but became mandatory for the 1970 model year. The wording on the decal was chosen by multiple choice by the manufactures (4) choices that would best suit there purposes of self compliances. If you would take the time to read the Compliance Decal of the 1970 -71 model year you would see that it self explanatory.
it reads " THIS VEHICLE CONFORMS TO ALL APPLICABLE U.S. FEDERAL MOTOR VEHICLE SAFTEY STANDARDS IN EFFECT ON THE DATE OF MANUFACTURE SHOWN ABOVE" key words conforms, applicable, in effect on the date of manufacture shown above. noting the vehicle was manufactured by the Safety Standards in effect on that particular date. nothing about the date the vehicle was finished or assembled. that is not an opinion it is simply what it states.
Re: highest vin conv. barracuda [Re: Little Detroit] #2272027
03/18/17 10:03 PM
03/18/17 10:03 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Please stop with the smoke screens, the subject line was about 1971 barracuda's. 1970 was the first model year "required" to have the Compliance Decal. Please take note of the date of posted "document", If read it correctly it is dated 1972. The First "compliance decal" was first used on some but not all Daytona's but became mandatory for the 1970 model year. The wording on the decal was chosen by multiple choice by the manufactures (4) choices that would best suit there purposes of self compliances. If would take the time to read the Compliance Decal of the 1970 -71 model year you see that it self explanatory.
shruggy
Re: highest vin conv. barracuda [Re: Alaskan_TA] #2877057
01/20/21 09:43 AM
01/20/21 09:43 AM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
Stumbled on thread again. BH27G1B438384 - not mine. Not sure where I got the pict even.
Re: highest vin conv. barracuda [Re: Vert] #2877436
01/20/21 05:41 PM
01/20/21 05:41 PM
Mattituck NY.
FJ6AAR Offline
FJ6AAR  Offline
Mattituck NY.
I have a 1970 Barracuda hardtop with 438341..... I know, it has nothing to do whatsoever with this thread...lol
1970 Hemi 'Cuda hard top clone
1971 Hemi 'Cuda Convertible clone
