Page 1 of 3 1 2 3
Best Way To Cut 8AN Line #224456
02/14/09 01:46 PM
02/14/09 01:46 PM
U.S.
moparniac Offline OP
U.S.
Mopar Performance
Re: Best Way To Cut 8AN Line [Re: moparniac] #224457
02/14/09 01:51 PM
02/14/09 01:51 PM
in a chair
mopartony Offline
mopartony  Offline
in a chair
If you have a steel cut off wheel on a grinder that is the best way.
I use, duct tape, a sharp chisel, a 2.5lbs short handle hammer, the cement on the drive or garage and one good whack! It may take 2-3 though.
In the 2-3 case better hope your name is not lightining. You know it never hits the same place twice.
Re: Best Way To Cut 8AN Line [Re: mopartony] #224458
02/14/09 02:06 PM
02/14/09 02:06 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
You need some reinforced tape to wrap the end (this keeps the wire from fraying. A cutoff wheel, or a pair of good snips, or cutters. I prefer the cutters over the cutoff wheel/grinder cause this tends to burn the rubber up at the end hose.
Re: Best Way To Cut 8AN Line [Re: moparniac] #224459
02/14/09 02:06 PM
02/14/09 02:06 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I like using a abrasive chop saw. Makes a perfect cut that doesn't fray the stainless braid. Wrap it in masking tape and cut. Besure to rinse out the inside of the hose before and after installing the ends. A die grinder with a cutoff wheel will do the trick too.
Re: Best Way To Cut 8AN Line [Re: Challenger 1] #224460
02/14/09 02:11 PM
02/14/09 02:11 PM
U.S.
U.S.
maybe a dremel with a cutoff wheel
Mopar Performance
Re: Best Way To Cut 8AN Line [Re: moparniac] #224461
02/14/09 02:15 PM
02/14/09 02:15 PM
Q
Quicktree Offline
Quicktree  Offline
Q
that may work, use black electrical tape pulled tight.
Re: Best Way To Cut 8AN Line [Re: Quicktree] #224462
02/14/09 02:26 PM
02/14/09 02:26 PM
Creston, Iowa
3
340man4ever Offline
340man4ever  Offline
Creston, Iowa
Black tape end, metal hose clamp tight and cut with cutoff wheel as close to the clamp as possible- keeps it from unraveling (sp?). Works great for the novice like me! good luck
Curator at Adams County Speed Shop
Post deleted by Defbob [Re: 340man4ever] #224463
02/14/09 02:53 PM
02/14/09 02:53 PM
Re: Best Way To Cut 8AN Line #224464
02/14/09 03:18 PM
02/14/09 03:18 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Do you guys keep the tape on the ends when you assemble the hose end?
Re: Best Way To Cut 8AN Line #224465
02/14/09 03:20 PM
02/14/09 03:20 PM
Delmont, Pa.
SRT8Challenger Offline
Delmont, Pa.
I black tape it, Block of aluminum, big sharp chisel and one hard blow with a big heavy hammer.
Nice clean cut with no debree. Works great!
Ed
Re: Best Way To Cut 8AN Line [Re: mopowers] #224466
02/14/09 03:57 PM
02/14/09 03:57 PM
Q
Quicktree Offline
Quicktree  Offline
Q
no, take it off being careful not to screw with the braided line.
Re: Best Way To Cut 8AN Line [Re: Quicktree] #224467
02/14/09 04:43 PM
02/14/09 04:43 PM
U.S.
U.S.
I left strapping tape on my 6an stuff before....... no issues.... my handheld cutters cut nice though the 6an stuff....... wont cut through the 8an stuff....
Mopar Performance
Re: Best Way To Cut 8AN Line [Re: moparniac] #224468
02/14/09 04:52 PM
02/14/09 04:52 PM
Coronado, CA
go-fish Offline
go-fish  Offline
Coronado, CA
Couple of wraps of masking tape and a bang saw.
70 'cuda: ProCharged 408, Tremec 5 speed, S60,triangulated 4 link, Hydroboost and Wilwoods
Re: Best Way To Cut 8AN Line [Re: go-fish] #224469
02/14/09 05:10 PM
02/14/09 05:10 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
A couple raps of masking tape works well, i use a thin cutoff wheel on a 4 1/2 " grinder. I cut in the middle of the tape so the next piece is ready to go. I do leave the tape on to install the fitting to contain the braid so it doesn't fray, after starting remove the tape and continue install. I think which ever way you do it,it is most critical you flush the lines out throughly.It doesn't take much to jam your needle/seat in your carb and you sure don't want that crap in your oil if your plumbing a oil set up.
Re: Best Way To Cut 8AN Line [Re: 340man4ever] #224470
02/14/09 05:56 PM
02/14/09 05:56 PM
NC
440Jim Offline
440Jim  Offline
NC
That is a good method. The clamp will help keep the cut straight all the way around. As other's have stated, clean out the hose after cutting with an abrasive wheel.
Post deleted by Defbob [Re: 440Jim] #224471
02/14/09 07:33 PM
02/14/09 07:33 PM
Re: Best Way To Cut 8AN Line #224472
02/14/09 11:07 PM
02/14/09 11:07 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
I used to use the wizz wheel but for 35.00 I broke down and bought a cutter at Home Depot that is much easier and leaves a cleaner cut
BINGO,works great and also crimps the hose in slightly so it slides easily into the fitting.
Re: Best Way To Cut 8AN Line #224473
02/14/09 11:13 PM
02/14/09 11:13 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
only 35.00
Something like that is much better. Go to an electrical supply house and buy a big pair like linemen use to cut cable about 3.5 feet long and they'll cut everything up to -16. No taping, grinding, or cleanup mess.
Re: Best Way To Cut 8AN Line #224474
02/14/09 11:19 PM
02/14/09 11:19 PM
NC
440Jim Offline
440Jim  Offline
NC
only 35.00
Nice !
Re: Best Way To Cut 8AN Line [Re: 440Jim] #224475
02/14/09 11:30 PM
02/14/09 11:30 PM
so cal
cmcgee123 Offline
cmcgee123  Offline
so cal
only 35.00
Nice !
but if i use those, how am i supposed to cut my fingers
nitrous is like a really hot chick with an std you want to hit it but youre affraid of the outcome.
Page 1 of 3 1 2 3
