Re: Best Way To Cut 8AN Line
[Re: moparniac]
#224457
02/14/09 01:51 PM
02/14/09 01:51 PM
Posts: 4,421 in a chair
mopartony
in a chair
If you have a steel cut off wheel on a grinder that is the best way. I use, duct tape, a sharp chisel, a 2.5lbs short handle hammer, the cement on the drive or garage and one good whack! It may take 2-3 though. In the 2-3 case better hope your name is not lightining. You know it never hits the same place twice.
[Re: mopartony]
#224458
02/14/09 02:06 PM
02/14/09 02:06 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
You need some reinforced tape to wrap the end (this keeps the wire from fraying. A cutoff wheel, or a pair of good snips, or cutters. I prefer the cutters over the cutoff wheel/grinder cause this tends to burn the rubber up at the end hose.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: moparniac]
#224459
02/14/09 02:06 PM
02/14/09 02:06 PM
Challenger 1
Cincinnati, Ohio
I like using a abrasive chop saw. Makes a perfect cut that doesn't fray the stainless braid. Wrap it in masking tape and cut. Besure to rinse out the inside of the hose before and after installing the ends. A die grinder with a cutoff wheel will do the trick too.
Post deleted by Defbob
[Re: 340man4ever]
#224463
02/14/09 02:53 PM
02/14/09 02:53 PM
[Re: mopowers]
#224466
02/14/09 03:57 PM
02/14/09 03:57 PM
Quicktree
Do you guys keep the tape on the ends when you assemble the hose end?
no, take it off being careful not to screw with the braided line.
[Re: Quicktree]
#224467
02/14/09 04:43 PM
02/14/09 04:43 PM
Posts: 6,295 U.S.
moparniac
U.S.
I left strapping tape on my 6an stuff before....... no issues.... my handheld cutters cut nice though the 6an stuff....... wont cut through the 8an stuff....
Mopar Performance
[Re: go-fish]
#224469
02/14/09 05:10 PM
02/14/09 05:10 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
A couple raps of masking tape works well, i use a thin cutoff wheel on a 4 1/2 " grinder. I cut in the middle of the tape so the next piece is ready to go. I do leave the tape on to install the fitting to contain the braid so it doesn't fray, after starting remove the tape and continue install. I think which ever way you do it,it is most critical you flush the lines out throughly.It doesn't take much to jam your needle/seat in your carb and you sure don't want that crap in your oil if your plumbing a oil set up.
[Re: 340man4ever]
#224470
02/14/09 05:56 PM
02/14/09 05:56 PM
Posts: 16,928 NC
440Jim
NC
Black tape end, metal hose clamp tight and cut with cutoff wheel as close to the clamp as possible-
That is a good method. The clamp will help keep the cut straight all the way around. As other's have stated, clean out the hose after cutting with an abrasive wheel.
[Re: 440Jim]
#224471
02/14/09 07:33 PM
02/14/09 07:33 PM
#224472
02/14/09 11:07 PM
02/14/09 11:07 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
I used to use the wizz wheel but for 35.00 I broke down and bought a cutter at Home Depot that is much easier and leaves a cleaner cut
BINGO,works great and also crimps the hose in slightly so it slides easily into the fitting.
#224473
02/14/09 11:13 PM
02/14/09 11:13 PM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
only 35.00
Something like that is much better. Go to an electrical supply house and buy a big pair like linemen use to cut cable about 3.5 feet long and they'll cut everything up to -16. No taping, grinding, or cleanup mess.
#224474
02/14/09 11:19 PM
02/14/09 11:19 PM
Posts: 16,928 NC
440Jim
NC
only 35.00
Nice !
