Re: 496 BB with Jeep cam sensor
[Re: Mopar_Rich]
#2244347
01/30/17 11:30 PM
01/30/17 11:30 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Thats a very nice setup. Is your question will the Jeep cam sensor work ? Or is it something you heard some guys are doing and need to know what needs to be modified ? I cant really help you as all I can tell you is that cam sensor should be a three wire Hall Effect style sensor. It needs a ground , a signal wire from the PCM which is 5 volts and a power up wire which could be from 5 to 12 volts as Mopar used a few different voltages on the power wire to the Hall Effect sensors over the years as I have seen 12 , 9 , 8 and 5 volts on the power wire. Good luck with that cool setup. Ron
[Re: Mopar_Rich]
#2244391
01/31/17 12:14 AM
01/31/17 12:14 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I did a 360 six pack using canibalized carbs for throttle bodies once. It also has DIS ignition (ELECTROMOTIVE) No cam sensor though! I just did a jeep cam sensor mod to a factory distributor for MR Pbody. I have a little drawing if anyone needs dimensions.
[Re: Mopar_Rich]
#2244397
01/31/17 12:25 AM
01/31/17 12:25 AM
TRENDZ
Milwaukee WI
Rich, very nice job on the harness layout. Best work I've seen for a custom job. I do recommend you when asked.
[Re: Mopar_Rich]
#2244535
01/31/17 05:16 AM
01/31/17 05:16 AM
TRENDZ
Milwaukee WI
Rich, do you use 5volt or 12volt supply voltage on the cam sensor? I've installed these on a few systems and always used 5volt. I sold one to a guy that used 12 volt supply and it still works, so the operating range seems forgiving. I noticed most of the specs for cherry sensors have a fairly wide v range. I did bench test one and noticed the rising edge is rounded without a pull up resistor. The falling edge is sharp. Not sure if the Holley systems add the resistor in the ECU, but system logs look good without any added resistor.
[Re: Mopar_Rich]
#2244595
01/31/17 12:11 PM
01/31/17 12:11 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Did you use the bushing from Jerry at SD concepts? Its a very nice piece and he sells one to drop the Jeep sensor in a big or small block.
Trendz, I had to use a resistor with my MS3X to make the jeep sensor work properly.
Rich that is a really cool project. I just got an old Holley Tunnel ram I am converting to EFI so I can use it on my W2 416.
68 Barracuda Formula S 340
[Re: Mopar_Rich]
#2244645
01/31/17 01:27 PM
01/31/17 01:27 PM
Posts: 19,375 Las Vegas
Al_Alguire
Las Vegas
Looks awesome!! Hey Rich thinking of converting the TS car over to FI. I have just never attempted an EFI deal before so doing some research on whats out there now.
[Re: Mopar_Rich]
#2244932
01/31/17 09:08 PM
01/31/17 09:08 PM
TRENDZ
Milwaukee WI
Here is the connector part number. Any mopar dealer can get it. Also a scope shot of the trigger event. Going high is rounded. Going low is sharp.
[Re: Mopar_Rich]
#2244935
01/31/17 09:13 PM
01/31/17 09:13 PM
TRENDZ
Milwaukee WI
Nice to see support from you vendors embracing the mopar stuff.
