what is a good way to clean polish taillight lens #2244055
01/30/17 04:47 PM
01/30/17 04:47 PM
dracut mass usa
sparcy Offline OP
sparcy  Offline OP
dracut mass usa
my 68 charger tail lights I took all apart to refinish them . any way to polish up the lens
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: what is a good way to clean polish taillight lens [Re: sparcy] #2244062
01/30/17 04:55 PM
01/30/17 04:55 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
Meguiar's #17 Plastic Cleaner and #10 Plastic Polish.
1972 Dodge Challenger
Re: what is a good way to clean polish taillight lens [Re: sparcy] #2244074
01/30/17 05:11 PM
01/30/17 05:11 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I purchased a "string" buff from ( I think) Eastwood, that is designed for plastic, for my buffer.. Used some plastic buffing compound and WOW, like new......
Re: what is a good way to clean polish taillight lens [Re: sparcy] #2244089
01/30/17 05:37 PM
01/30/17 05:37 PM
Ottawa, Ontario
L.R Helbling Offline
Ottawa, Ontario
this is the one I swear buy. Tried it on my 2005 Chrysler 300C. Beautiful results!
and then you can reuse the polishing pad for your next project.
http://3mauto.com/products/headlight-restoration/3m-lens-renewal-kit-39014.html#vWj6BczmCdPkx6Tc.97
Re: what is a good way to clean polish taillight lens [Re: minivan] #2244205
01/30/17 08:38 PM
01/30/17 08:38 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
UH-huh...
Floppy and some rouge...
Go slow...
Re: what is a good way to clean polish taillight lens [Re: sparcy] #2244238
01/30/17 09:17 PM
01/30/17 09:17 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
I hand polish with mothers mag wheel polish with excellent results.
Re: what is a good way to clean polish taillight lens [Re: sparcy] #2244275
01/30/17 10:10 PM
01/30/17 10:10 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
If you want them to look like new AND stay that way.....clear coat them. Lightly scuff them and clean them good, then have a body shop spray them with clear. It will only take an once or two, usually about what they throw out when painting a part.
The clear will really make the lenses snap, even in the nooks and crannies that you cannot get to to polish. And it is even harder than the plastic, so it holds up better.
Master, again and still
Re: what is a good way to clean polish taillight lens [Re: PLUM_72] #2244315
01/30/17 10:54 PM
01/30/17 10:54 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
X2 . . . took my time and did quite a few applications on my 70 Sport Satllite. Afterwards, I will take "cleaner/wax" every now and then on the lenses - keeps them like new.
Re: what is a good way to clean polish taillight lens [Re: sparcy] #2244355
01/30/17 11:38 PM
01/30/17 11:38 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
When I bought my 65 Cuda some 20+ years ago the rear lenses had holes in them from blue dots (not legal in TX). So I had some repair work to do. I cleaned them, used that Permatex lense repair epoxy to fix the holes, then wet sanded them with Testors (the model car people) ultra fine sand paper. Still look great today.
Whatever they used for plastic back then holds up better than what they use today.
Don't be the exception.
Re: what is a good way to clean polish taillight lens [Re: a12rag] #2244356
01/30/17 11:38 PM
01/30/17 11:38 PM
IN
ahy Offline
ahy  Offline
IN
Common polishing compound has worked well for me for initial clean up. Then the Eastwood 3 step plastic polishing system... which finishes with a clear protective coat. Not clearcoat exactly but similar.
Re: what is a good way to clean polish taillight lens [Re: ahy] #2244614
01/31/17 12:43 PM
01/31/17 12:43 PM
moparx Offline
moparx  Offline
has anyone ever tried the spray can clear that is intended for wheels on lenses ? supposedly, it is pretty tough stuff ?
beer
Re: what is a good way to clean polish taillight lens [Re: moparx] #2244945
01/31/17 09:35 PM
01/31/17 09:35 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
We scuff and clear many headlights. The spray bomb stuff doesn't stick to them, it just falls off. I guess the gun clear has solvents that bite the plastic. Now I haven't tried spray bomb clear on taillights, only headlights. But it is safe to assume that the 2 clears would act the same on the 2 plastics.
Re: what is a good way to clean polish taillight lens [Re: sparcy] #2244949
01/31/17 09:38 PM
01/31/17 09:38 PM
PA
70Duster Offline
70Duster  Offline
PA
If you use SprayMax 2K clear, it will stick.
Re: what is a good way to clean polish taillight lens [Re: 70Duster] #2244995
01/31/17 10:54 PM
01/31/17 10:54 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
I see no need to clear...
I got 20+ years on a set of NOS t-light lenses...
On a car that gets driven...
I keep 'em clean...
They are still like new...
Re: what is a good way to clean polish taillight lens [Re: 70Duster] #2245229
02/01/17 12:45 PM
02/01/17 12:45 PM
moparx Offline
moparx  Offline
any link please ? does this have a button you push to introduce a hardening agent ? the products i have seen that use the button seem to be decent paints, but it seems to be a waste when a guy only needs a spritz or two. i guess using a "preval" type air/spray unit would be a better compromise. are these type sprayers available with a fan spray nozzle now ? i know the original units were using just a regular spray can nozzle.
beer
Re: what is a good way to clean polish taillight lens [Re: sparcy] #2245484
02/01/17 07:54 PM
02/01/17 07:54 PM
md
md
I keep 'em clean...
I agree, I see no need for clear on tail lights.
Re: what is a good way to clean polish taillight lens [Re: mopars4ever] #2245547
02/01/17 09:38 PM
02/01/17 09:38 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Spraying taillights with clear is not a necessity, but it has some very real advantages. And is worth considering given that it is less work and can be done for less than the cost of plastic polish.
Just offering an alternative to polishing should the OP wish to consider it.
