what is a good way to clean polish taillight lens
#2244055
01/30/17 04:47 PM
01/30/17 04:47 PM
Posts: 342 dracut mass usa
sparcy
dracut mass usa
my 68 charger tail lights I took all apart to refinish them . any way to polish up the lens
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: what is a good way to clean polish taillight lens
[Re: sparcy]
#2244062
01/30/17 04:55 PM
01/30/17 04:55 PM
Posts: 1,233 Chicago, IL
PLUM_72
Chicago, IL
Meguiar's #17 Plastic Cleaner and #10 Plastic Polish.
1972 Dodge Challenger
[Re: minivan]
#2244205
01/30/17 08:38 PM
01/30/17 08:38 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
I purchased a "string" buff from ( I think) Eastwood, that is designed for plastic, for my buffer.. Used some plastic buffing compound and WOW, like new...... UH-huh... Floppy and some rouge... Go slow...
[Re: sparcy]
#2244275
01/30/17 10:10 PM
01/30/17 10:10 PM
Posts: 12,087 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
If you want them to look like new AND stay that way.....clear coat them. Lightly scuff them and clean them good, then have a body shop spray them with clear. It will only take an once or two, usually about what they throw out when painting a part.
The clear will really make the lenses snap, even in the nooks and crannies that you cannot get to to polish. And it is even harder than the plastic, so it holds up better.
Master, again and still
[Re: PLUM_72]
#2244315
01/30/17 10:54 PM
01/30/17 10:54 PM
Posts: 2,918 Calgary, Alberta Canada
a12rag
Meguiar's #17 Plastic Cleaner and #10 Plastic Polish. X2 . . . took my time and did quite a few applications on my 70 Sport Satllite. Afterwards, I will take "cleaner/wax" every now and then on the lenses - keeps them like new.
[Re: sparcy]
#2244355
01/30/17 11:38 PM
01/30/17 11:38 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
When I bought my 65 Cuda some 20+ years ago the rear lenses had holes in them from blue dots (not legal in TX). So I had some repair work to do. I cleaned them, used that Permatex lense repair epoxy to fix the holes, then wet sanded them with Testors (the model car people) ultra fine sand paper. Still look great today.
Whatever they used for plastic back then holds up better than what they use today.
[Re: moparx]
#2244945
01/31/17 09:35 PM
01/31/17 09:35 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
We scuff and clear many headlights. The spray bomb stuff doesn't stick to them, it just falls off. I guess the gun clear has solvents that bite the plastic. Now I haven't tried spray bomb clear on taillights, only headlights. But it is safe to assume that the 2 clears would act the same on the 2 plastics.
[Re: sparcy]
#2245484
02/01/17 07:54 PM
02/01/17 07:54 PM
Posts: 13,593 md
mopars4ever
md
I see no need to clear...
I got 20+ years on a set of NOS t-light lenses...
On a car that gets driven...
I keep 'em clean...
They are still like new... I agree, I see no need for clear on tail lights.
[Re: mopars4ever]
#2245547
02/01/17 09:38 PM
02/01/17 09:38 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Spraying taillights with clear is not a necessity, but it has some very real advantages. And is worth considering given that it is less work and can be done for less than the cost of plastic polish.
Just offering an alternative to polishing should the OP wish to consider it.
