Fuel return line using 71 ECS system?
#2242970
01/28/17 07:23 PM
01/28/17 07:23 PM
Posts: 8,148 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
I have a 72 Cuda with the 71 style ECS "seperator". I am installing a Fi Tech fuel system and planned to use the 1/4" {EDIT} vent line to the vapor seperator but if the canistor was meant to catch the vapors and the carb used them, without the canister then I wont really be vented at all will I ?
Re: Fuel return line using 71 ECS system?
[Re: ahy]
#2243693
01/29/17 11:31 PM
01/29/17 11:31 PM
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
The fuel return line should go right back to the fuel pickup and dump the fuel in the tank. Fuel pickups with 1/4" return line are readily available.
The ECS system does make a great tank vent setup. Much better than a vented fuel cap which can hold quite a bit of pressure or vacuum before venting.
As far as the rest of the system, what does it look like? If you are thinking of a frame mounted high pressure pump be careful. High pressure pumps do not like to suck. Noise and early failure follow. In tank pump or one of the sump systems fed by a low pressure pump are much better. Ooops I meant it's a vent line not a return line, no return line is required for the set up I am using, and the previous posts above show the Command center type pump I am using. It has it's own sump fed by the OE style factory fuel pump.
[Re: UCUDANT]
#2247111
02/04/17 11:59 AM
02/04/17 11:59 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I see what your saying. As the factory unit was a sealed setup with the charcoal canister and the tank vent line vented to the charcoal canister. But the unit you are using has to be vented to the gas tank so you plan to use the original vent line to the canister to go to your new units vent to the tank. And you need to have the factory tank vented of course. They make vented caps that are vented at all times or at least they use to. The newer caps as stated will vent at a certain vacum or pressure release but are made as to only vent under enough vacum or pressure before it gets to much to damage the tank. Are you planing to use the factory vapor seperator setup ? Course if you dont you could plug them vent lines to it and use one for the tank vent and then run a tank vent line from it. Or if you can get a normal fully vented cap you can use it as my 63 uses a vented cap as the tank itself has no vent line from it or from the filler neck. When I lost my cap and could not find the one I needed right away I put a small slit in a pressure/vacum cap rubber gasket so my tank would vent all the time until I got the right cap. Course with any vented tank you may get fuel smell in the garage on hot summer days unless you you use a canister vent setup. Good luck with it.
I take it that setup takes the 5 or 6 psi from the stock fuel pump and ups it at that unit for the fuel injection setup ? What fuel pressure does that setup run at ? Ron
[Re: UCUDANT]
#2247850
02/05/17 04:52 PM
02/05/17 04:52 PM
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
No problem Ron. cnxt I looked at the Specta EFI tank and went this route to prevent running lines... that didn't go as planned I wanted to be able to convert back to stock as easily as possible while swapping any peformance parts generically to another mopar. Plus these items were designed to work together. I can always change/upgrade any EFI parts later though too. How do you like your system? I am questioning the level at which my return would be. They state it needs to be above the fuel level. Do I need to T it into a line as it enters the fuel vapor seperator rather than the return nipple at the fuel sending unit?
[Re: UCUDANT]
#2249302
02/07/17 08:51 PM
02/07/17 08:51 PM
Challenger 1
Cincinnati, Ohio
Ok newest idea:
The tanks going to be vented via the fwd most line from the fuel vapor seperator fwd to the engine.
I think I can take the return "vent" from the Command center and T it into the line shown. Thoughts? That is the same as what I suggested earlier, only I said T it in up front. Like I said earlier, vent the pump sump/comand center to the vent line at the valve cover breather. Tee it in there, why run it all the way to the rear when the factory vent line ends at the valve cover breather? Mount the sump as low as you can up front.
[Re: UCUDANT]
#2249467
02/08/17 01:24 AM
02/08/17 01:24 AM
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
Because it's not a true "vent"... it will return raw fuel
[Re: UCUDANT]
#2251672
02/11/17 03:55 PM
02/11/17 03:55 PM
Posts: 4,755 Florida
BDW
