Page 2 of 4 1 2 3 4
Re: A few questions about my transmission [Re: ProSport] #2242201
01/27/17 12:27 PM
01/27/17 12:27 PM
an8sec70cuda Offline
Bob...if it's real close, the oil pan can just sit on the drag link. I use a small piece of 1x4 board to let it sit on when I take the trans out. Just loosen up your plate bolts at the frame.
I don't think it's really necessary to put a bolt in sprag in a trans that's currently in good working condition. Just my opinion.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: A few questions about my transmission [Re: ProSport] #2242203
01/27/17 12:36 PM
01/27/17 12:36 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Originally Posted By ProSport
Thanks guys.
I don't run a speedometer Cable, it looks like it's leaking a tiny amount of tranny fluid where the speedo Cable would attach. Is there a cap or something available to cap that off?
use a 1 49/64" freeze plug. Dorman 555-036
Re: A few questions about my transmission [Re: ProSport] #2242236
01/27/17 01:27 PM
01/27/17 01:27 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Thanks guys! It's nice to have a game plan.
Re: A few questions about my transmission [Re: ProSport] #2242300
01/27/17 03:21 PM
01/27/17 03:21 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
As already stated, the super or ultra sprags have six tapped holes where two additional holes have to be drilled in the case. The placement of these holes can either be marked out manually or one can purchase a jig from A&A to help with drilling these two holes.
http://www.aandatrans.com/Departments/Chrysler-727-Trans/Bolt-In-Sprag.aspx?page=3
Drilling these holes on an older case is not a problem but on the later cases, there is a boss that you have to drill through and needs to be counterbored in order to make room for the socket head capscrew. This can be done on a mill or one can use a counterbore reamer to clearance the holes after the through holes are drilled.
Re: A few questions about my transmission [Re: Hot 340] #2242329
01/27/17 04:19 PM
01/27/17 04:19 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Thanks guys.
(X2)
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: A few questions about my transmission [Re: ProSport] #2242347
01/27/17 04:48 PM
01/27/17 04:48 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've seen even Super Sprague break during drive train failure. Also seen sprages break with low bamd apply. Good shield or blanket is your best bet. And even then stuff may get through it. I personnaly have never blown up a drum (stock or aftermarket) in 35 years. But seen my fair share of them cause damage. I'd buy a good drum before a sprage.
Doug
Re: A few questions about my transmission [Re: ProSport] #2242363
01/27/17 05:18 PM
01/27/17 05:18 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Yeah. I agree with the general sentiment. I wouldn't chase replacing the sprag. Do your burn outs starting out in second gear.
I have stripped axles and torn up an 8.75 rear, both at the hit, and never messed up the sprag.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: A few questions about my transmission [Re: J_BODY] #2242364
01/27/17 05:19 PM
01/27/17 05:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted By J_BODY
....and I'd be more concerned about the front drum than the sprag. Aluminum or the billet steel piece for sure.
iagree Replace the drum before replacing the sprag.
Re: A few questions about my transmission [Re: John_Kunkel] #2242454
01/27/17 08:51 PM
01/27/17 08:51 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
same here, the only reason I changed mine was I was already in it.
Re: A few questions about my transmission [Re: ProSport] #2242615
01/28/17 01:51 AM
01/28/17 01:51 AM
Dallas, TX
440Brian Offline
440Brian  Offline
Dallas, TX
I use a Harbor Freight engine support bar
http://www.harborfreight.com/1000-lb-capacity-engine-support-bar-96524.html
I use the rear center intake valley cover bolt hole. Car can still be moved (pushed or lifted).
Re: A few questions about my transmission [Re: ProSport] #2242651
01/28/17 03:08 AM
01/28/17 03:08 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I can tell you I still have the factory drum in my 63 and I do have a bolt in sprag but its not the super sprag. I do use a trans blanket and have never blown up a 727 but I dont race alot like many do. I just make sure I am aware of what I run and start my burnouts in second. And I dont roll out of the water and let the tires squeal. I let off the gas and then when the tires slow down I just idle out and then pull up and stage. Actually my brother ran low 9's at one time in his Cuda with still the stock sprag in the car and it held up fine until he changed it. I am not saying its good to run the stock drum and sprag as I am just stating that I have got away on the stock drum in what little racing I do and trying to be smart about it since I do know what can happen even though I have never blown a 727 or saw one blow up. Thats also one reason I dont race much and wont until I update the drum. Ron
Re: A few questions about my transmission [Re: ProSport] #2242705
01/28/17 11:17 AM
01/28/17 11:17 AM
moparx Offline
moparx  Offline
Thanks guys.
pm me with your mailing address and i will send you a screw on cap that has a rubber seal inside. no charge.
beer
Re: A few questions about my transmission [Re: moparx] #2242778
01/28/17 01:56 PM
01/28/17 01:56 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Thanks guys.
beer
PM sent, thank you sir!!!
Re: A few questions about my transmission [Re: 440Brian] #2242783
01/28/17 02:06 PM
01/28/17 02:06 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Interesting. So basically the rubber pads will sit on top of your inner fenders, and the metal bar doesn't touch anything? I just wouldn't want anything sitting on top of the (outer)fenders.
Re: A few questions about my transmission [Re: ProSport] #2242786
01/28/17 02:11 PM
01/28/17 02:11 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I got ahold of Chuck Lofgren and luckily he still makes and sells the shorty non-sfi blankets for $149, he only has one left and I won't have my money together til spring as I have other projects going on right now. I'll order one in the spring when he produces more of them.
Re: A few questions about my transmission [Re: ProSport] #2243225
01/29/17 02:33 AM
01/29/17 02:33 AM
Dallas, TX
440Brian Offline
440Brian  Offline
Dallas, TX
Exactly. I have a lift off hood and no hinges so I move the support bar as far rearward as possible, the rear foot right at the hinge opening.
Re: A few questions about my transmission [Re: ProSport] #2243411
01/29/17 03:38 PM
01/29/17 03:38 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Ok thanks I'll buy one of those if my other efforts don't work. Harbor freight is only 15 min from my house.
Re: A few questions about my transmission [Re: ProSport] #2243417
01/29/17 03:49 PM
01/29/17 03:49 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
A simple 2 x 4 cut to size and a small chain works as well too. Or a wood spacer between the oil pan and steering link like Chip suggests. I have the spool mounts on my 73 Sport, and don't even use any extra supports. wouldn't want to do that with the bisket type mounts that you most likely have.
Re: A few questions about my transmission [Re: ProSport] #2243459
01/29/17 05:23 PM
01/29/17 05:23 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I just have an AR-Engineering motor plate.
Re: A few questions about my transmission [Re: ProSport] #2243470
01/29/17 05:36 PM
01/29/17 05:36 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Just me personally I'm not pulling a transmission to just put a bolt in sprag in. I do have one but I also put in a steel drum.
Page 2 of 4 1 2 3 4
