Beam axles? #2242080
01/27/17 01:45 AM
01/27/17 01:45 AM
Freeport IL USA
poorboy Offline OP
poorboy  Offline OP
Freeport IL USA
Did Dodge start putting the beam/straight axles under 2 wheel drive trucks again? If so, when did they start?
Someone told me they did, but I haven't been under much of anything newer then a 2000 truck, so I'm asking. Gene
Re: Beam axles? [Re: poorboy] #2242098
01/27/17 02:38 AM
01/27/17 02:38 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Nope, no straight axles on the front of 2wd's since '71 (ASSuming that's what you're referring to)
Re: Beam axles? [Re: poorboy] #2242110
01/27/17 04:04 AM
01/27/17 04:04 AM
ND
dodgedon Offline
dodgedon  Offline
ND
How big of a truck are we talking about? Some of the 1 tons and larger have a tube type front on coils. I know i saw cab and chassis 3500's around 97 with tube front axles. I believe the 4500-5500's around 2008 and up do too.
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: Beam axles? [Re: poorboy] #2242159
01/27/17 10:25 AM
01/27/17 10:25 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Agree with 3500's and up lately. See them out there.
Re: Beam axles? [Re: buildanother] #2242234
01/27/17 01:24 PM
01/27/17 01:24 PM
Austin, TX
lunacy Offline
lunacy  Offline
Austin, TX
3500 Chassis cabs (heavier gvwr) have been straight axle since 94 body style. The pickup 3500s stayed with IFS. It's still this way.
Re: Beam axles? [Re: poorboy] #2242429
01/27/17 07:48 PM
01/27/17 07:48 PM
Freeport IL USA
poorboy Offline OP
poorboy  Offline OP
Freeport IL USA
So the 3500 and bigger cab & chassis frames (not pickups) from 94 and up have a tube axle with coil springs. I learned something today! Thanks guys, that is the info I was looking for. Gene
Re: Beam axles? [Re: poorboy] #2242716
01/28/17 11:42 AM
01/28/17 11:42 AM
E
earlymopar Offline
earlymopar  Offline
E
Speaking for the older trucks at least, they have never had straight axles. They are dropped axles. A straight axle is straight and does not have a drop in the section between the springs.
- EM
