Re: Headers for 1965 B-body
[Re: classof65]
#2241782
01/26/17 06:01 PM
01/26/17 06:01 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
TTi listing says fits 62-74 b body..... Low deck, Big block, std exhaust port height
[Re: classof65]
#2241806
01/26/17 06:58 PM
01/26/17 06:58 PM
Posts: 21,067 Niles , Ohio
therocks
Niles , Ohio
TTI and I believe Dougs or Doug Thorleys cant remember whic ones .I run old TTIs on my 65 440 2 inch.383 man Ron rund the dougs on his 63 same as 65.TTIS are like 650 or so I believe .Mine are at least 20 years old .Rocky
Chrysler Firepower
[Re: fourgearsavoy]
#2242142
01/27/17 08:30 AM
01/27/17 08:30 AM
Posts: 5,102 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Doug's D451 will fit, I have the D452 with 2" tubes and they fit perfectly Gus Gus, are you still using the 65 K frame? I have an old set of hookers that one tube passes thru the inner fender and returns to the collector for my 65. Would maybe consider another set of 452's for my 65 if they fit...
...FAFO...
[Re: skicker]
#2242193
01/27/17 12:05 PM
01/27/17 12:05 PM
Posts: 6,350 Aurora, Oh.
max_maniac
Aurora, Oh.
Doug's D451 will fit, I have the D452 with 2" tubes and they fit perfectly Gus Gus, are you still using the 65 K frame? I have an old set of hookers that one tube passes thru the inner fender and returns to the collector for my 65. Would maybe consider another set of 452's for my 65 if they fit... DoubleD has a 65 Dodge with a 4 speed and uses the Dougs headers and they fit perfect. We also use the same header on our 64 Dodge and both have the stock k member.
[Re: classof65]
#2244889
01/31/17 07:51 PM
01/31/17 07:51 PM
therocks
Niles , Ohio
TTi makes early ones.Mine are 2 inch and have been on my 440 since they were CPPA.Thats a long time.Rocky
Chrysler Firepower
