Shaker Base Plate Drain Hoses #224174
02/14/09 10:17 AM
02/14/09 10:17 AM
Land of 10,000 Lakes
44D6PAKCUDA Offline OP
Were the 2 E body shaker base plate drain hoses held on by a type of hose clamp or not? Thanks!!
Re: Shaker Base Plate Drain Hoses [Re: 44D6PAKCUDA] #224175
02/14/09 11:57 AM
02/14/09 11:57 AM
Soldotna,Alaska
RT_6_PakShaker Offline
super street
super street
Soldotna,Alaska
Yes the same clamp as used for the heater hose.
Re: Shaker Base Plate Drain Hoses [Re: RT_6_PakShaker] #224176
02/15/09 10:38 AM
02/15/09 10:38 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
speaking about the same hoses...where do they lay when they point down on a small block or big block....behind the alt and p/steering brackets or in front, side?...no what I mean?
Re: Shaker Base Plate Drain Hoses [Re: AARCONV] #224177
02/15/09 08:32 PM
02/15/09 08:32 PM
Fort Workin Tx
Day2Runner Offline
Day2Runner  Offline
Fort Workin Tx
4406 hose go between the the 2 halfs of the p/s bracket and behind the alternator hose should be 19 20 " long and BTW i moved the hose brackets down below the nipple so i can remove by hand
