OE heads and valve covers, cork gaskets........... #2238630
01/21/17 08:52 PM
01/21/17 08:52 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
Do you use RTV on both sides or just to the valve cover and dry to the head? What works best? Thank you!
Admiration For Multiple Carburetor Vehicles...
Re: OE heads and valve covers, cork gaskets........... [Re: Stewpar] #2238635
01/21/17 08:57 PM
01/21/17 08:57 PM
MI
MI Mopar Works Offline
MI
I use nothing. Just make sure you dont have a bent valve cover, use the right hardware and tighten everything in sequence.
MI Mopar Works (734)624-2212
Parts Sales
Restoration and detailing of all kinds of mopar hardware
https://www.facebook.com/MIMoparWorks/
Re: OE heads and valve covers, cork gaskets........... [Re: MI Mopar Works] #2238662
01/21/17 09:36 PM
01/21/17 09:36 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
What sequence? scope Just torque them in order?
Re: OE heads and valve covers, cork gaskets........... [Re: Stewpar] #2238850
01/22/17 02:58 AM
01/22/17 02:58 AM
MI
MI
I assume you are kidding. Always start from the inside out.
Parts Sales
Re: OE heads and valve covers, cork gaskets........... [Re: Stewpar] #2238851
01/22/17 03:03 AM
01/22/17 03:03 AM
RSNOMO Online rolleyes
Moparts Torchbearer
RSNOMO  Online Rolleyes
Moparts Torchbearer
Peen your covers and check for straightness...
You'll get longevity out of a high-temp gasket...
Re: OE heads and valve covers, cork gaskets........... [Re: Stewpar] #2239085
01/22/17 04:14 PM
01/22/17 04:14 PM
Mass
charge70 Offline
charge70  Offline
Mass
I straighten the valve covers real good and then glue the gasket to it.It helps if you have an extra cyl.head around as you can lightly bolt it on and let the glue dry overnite.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: OE heads and valve covers, cork gaskets........... [Re: Stewpar] #2240453
01/24/17 03:49 PM
01/24/17 03:49 PM
Troy,MI
Siba Offline
Siba  Offline
Troy,MI
Learn from my mistakes.... go with Superformance gaskets. The only set that seal 100% and last a long time. Instructions on torque and how to apply are included. Highly recommended.
Re: OE heads and valve covers, cork gaskets........... [Re: Stewpar] #2240493
01/24/17 04:57 PM
01/24/17 04:57 PM
Chicago
PurpleBeeper Offline
Chicago
Over the last 30 yrs. of running Mopar big blocks, I've only had cork gaskets work for me consistently. I've had trouble sealing all the 1/2-dozen other types I've tried. I do like to use a little adhesive/RTV to hold them in place on the valve covers during installation, but not necessary (just keeps gasket from slipping and keeps holes lined up).
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: OE heads and valve covers, cork gaskets........... [Re: Siba] #2240675
01/24/17 10:10 PM
01/24/17 10:10 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
I second this. I used Superformance Carbon-X gaskets the last time I had my covers off and it is the first time that I've ever had no leaks at all; they've been on for over a year. I used their pan gaskets too with a windage tray and had the same results, The whole engine is completely dry which I've never had with any gaskets I've used before. Some weep just a little oil but, I always had at least some small leak.
I will never use another gasket for these areas.
Re: OE heads and valve covers, cork gaskets........... [Re: Stewpar] #2241331
01/25/17 11:48 PM
01/25/17 11:48 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
As a historical note, correct me if I'm wrong, I think the cork composite gaskets came along long after most of these cars were built.
