OE heads and valve covers, cork gaskets...........
#2238630
01/21/17 08:52 PM
01/21/17 08:52 PM
Posts: 2,963 Wisconsin
Stewpar
Wisconsin
Do you use RTV on both sides or just to the valve cover and dry to the head? What works best? Thank you!
Admiration For Multiple Carburetor Vehicles...
Re: OE heads and valve covers, cork gaskets...........
[Re: MI Mopar Works]
#2238662
01/21/17 09:36 PM
01/21/17 09:36 PM
Stewpar
Wisconsin
I use nothing. Just make sure you dont have a bent valve cover, use the right hardware and tighten everything in sequence. What sequence? Just torque them in order?
[Re: Stewpar]
#2238850
01/22/17 02:58 AM
01/22/17 02:58 AM
Posts: 675 MI
MI Mopar Works
MI
I use nothing. Just make sure you dont have a bent valve cover, use the right hardware and tighten everything in sequence. What sequence? Just torque them in order? I assume you are kidding. Always start from the inside out.
[Re: Stewpar]
#2239085
01/22/17 04:14 PM
01/22/17 04:14 PM
Posts: 603 Mass
charge70
Mass
I straighten the valve covers real good and then glue the gasket to it.It helps if you have an extra cyl.head around as you can lightly bolt it on and let the glue dry overnite.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: Stewpar]
#2240453
01/24/17 03:49 PM
01/24/17 03:49 PM
Posts: 128 Troy,MI
Siba
Troy,MI
Do you use RTV on both sides or just to the valve cover and dry to the head? What works best? Thank you! Learn from my mistakes.... go with Superformance gaskets. The only set that seal 100% and last a long time. Instructions on torque and how to apply are included. Highly recommended.
[Re: Stewpar]
#2240493
01/24/17 04:57 PM
01/24/17 04:57 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
Over the last 30 yrs. of running Mopar big blocks, I've only had cork gaskets work for me consistently. I've had trouble sealing all the 1/2-dozen other types I've tried. I do like to use a little adhesive/RTV to hold them in place on the valve covers during installation, but not necessary (just keeps gasket from slipping and keeps holes lined up).
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: Siba]
#2240675
01/24/17 10:10 PM
01/24/17 10:10 PM
Posts: 889 Oh
parksr5
Oh
Do you use RTV on both sides or just to the valve cover and dry to the head? What works best? Thank you! Learn from my mistakes.... go with Superformance gaskets. The only set that seal 100% and last a long time. Instructions on torque and how to apply are included. Highly recommended. I second this. I used Superformance Carbon-X gaskets the last time I had my covers off and it is the first time that I've ever had no leaks at all; they've been on for over a year. I used their pan gaskets too with a windage tray and had the same results, The whole engine is completely dry which I've never had with any gaskets I've used before. Some weep just a little oil but, I always had at least some small leak. I will never use another gasket for these areas.
