Dynomax Ultra Flows - 440 b body #2240188
01/24/17 12:53 AM
01/24/17 12:53 AM
Troy,MI
Siba Offline OP
Siba  Offline OP
Troy,MI
Anyone running HP manifolds, 2 1/2 h-pipe system, Ultraflows, and 12" resonators in the tailpipes on a 440 b-body (1968)?
I added the tailpipe resonators to my Dynomax Super Turbos years ago because the drone would rattle my teeth. Made a big difference but the turbos are too quiet for my liking.
I did a lot of research on this forum regarding flow and it looks like the ultras are one of the best flowing mufflers. That should help my 440 (515hp) breathe a little better.
Re: Dynomax Ultra Flows - 440 b body [Re: Siba] #2240227
01/24/17 01:42 AM
01/24/17 01:42 AM
OT, what about some elec or vac cutouts? otherwise here is a BTT for ya. I've always heard good regarding Dynomax but dont remember if they were referring to super turbos or ultras.
Re: Dynomax Ultra Flows - 440 b body [Re: Siba] #2240260
01/24/17 03:19 AM
01/24/17 03:19 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
All I can tell you is I run a full 3" exh system with the Dyno-Max Ultra-Flows and I like them. Its not super loud at idle as its alot louder when on the gas hard but its actually not as loud as alot of cars at idle. Ron
Re: Dynomax Ultra Flows - 440 b body [Re: Siba] #2240496
01/24/17 05:08 PM
01/24/17 05:08 PM
an8sec70cuda Offline
One thing is certain, you will notice a seat of the pants improvement in power when you take those restrictive Super Turbos off and put the Ultraflows on.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Dynomax Ultra Flows - 440 b body [Re: Siba] #2240506
01/24/17 05:22 PM
01/24/17 05:22 PM
Chicago
PurpleBeeper Offline
Chicago
I recently saw a repeat of a "Power Block" TV show... Horsepower?...not sure, where they tested several mufflers on the same mule engine on a dyno. I think they might have used a LS-engine. Anyway, best to worst was a range of about 8-10hp max. improvement vs. stock muffler (on a street/strip build).
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Dynomax Ultra Flows - 440 b body [Re: Siba] #2240520
01/24/17 05:43 PM
01/24/17 05:43 PM
usa
Mopar1970440 Offline
usa
I pulled off my 2 1/2 ultra flows after a few years when I changed my exhaust to a 3" setup. When I took them off you could hear a lot of loose particles in them? They sounded like a Maraca when you shook the muffler...lol
Re: Dynomax Ultra Flows - 440 b body [Re: Mopar1970440] #2240611
01/24/17 08:12 PM
01/24/17 08:12 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I have them on my '63 Dodge.
I did turn downs in front of the rear axle.
No drone and they aren't loud at all.
'63 Dodge 330
11.19 @ 121 mph
Re: Dynomax Ultra Flows - 440 b body [Re: Siba] #2240683
01/24/17 10:28 PM
01/24/17 10:28 PM
Troy,MI
Siba Offline OP
Siba  Offline OP
Troy,MI
Thanks for the replies! I pulled the trigger on the welded Ultra Flows! Might have to remove the rear resonators after I do an initial trial.
