Automatic tranny fluid #2240056
01/23/17 10:06 PM
01/23/17 10:06 PM
Illinois
V
v10 Offline OP
v10  Offline OP
V
Illinois
I was going to drop the pan and change the automatic tranny fluid and filter in my 95 Dodge V10 pickup. The books say to use ATF plus tranny fluid. Will ATF plus4 work? I just wanted to make sure it won't hurt to have it mixed with what is in there now.
Thanks in advance,
V10
Re: Automatic tranny fluid [Re: v10] #2240109
01/23/17 11:08 PM
01/23/17 11:08 PM
IN
ahy Offline
ahy  Offline
IN
ATF+4 is a bit more slippery vs earlier fluids. It may work OK or not. I would suggest the recommended fluid.
Re: Automatic tranny fluid [Re: v10] #2240131
01/23/17 11:33 PM
01/23/17 11:33 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
As I recall, +4 was backward compatible with +3
http://www.allpar.com/mopar/transmissions/fluids.html
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Automatic tranny fluid [Re: v10] #2240186
01/24/17 12:51 AM
01/24/17 12:51 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Yes +4 ATF supersedes Dexron and ATF III in Mopar applications. Go ahead and use it.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Automatic tranny fluid [Re: 71yelladustr] #2240315
01/24/17 11:25 AM
01/24/17 11:25 AM
Illinois
V
v10 Offline OP
v10  Offline OP
V
Illinois
Thanks for the responses.
V10
Re: Automatic tranny fluid [Re: v10] #2240501
01/24/17 05:13 PM
01/24/17 05:13 PM
Chicago
PurpleBeeper Offline
Chicago
It might be just fine, but I was warned by my step-father many years ago never to mix transmission fluid since some combinations can "foam"..... for whatever that's worth.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Automatic tranny fluid [Re: PurpleBeeper] #2240566
01/24/17 06:44 PM
01/24/17 06:44 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
ok then based on the article -
1) “The previous MOPAR ATF+3® formulation was discontinued in 2005 and ATF+4® is recommended for all transmissions filled with ATF+3®.”
2)"You can use ATF+3 with all older Chrysler transmissions"
then i should be able to use 4 in my 1969 727 right?
and what is meant by 'shearing'?? shruggy
Re: Automatic tranny fluid [Re: mikemee1331] #2240572
01/24/17 07:02 PM
01/24/17 07:02 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
While mine was leaking profusely through the shifter seal I was topping mine off with ATF+4. But it's driven VERY little. I've had the leak repaired and fluid changed, the shop filled it with a "global synthetic", I've seen the spec sheet, it's compatible with everything, including things that are incompatible with each other? work shruggy
Check it out:
http://www.service-pro.com/documents/WarrenSpecs/WA-GlobalFullSynMulti-VehicleATF.pdf
I dunno whether to leave it in there and be happy or what. confused
Robert
'69 300 Convertible
'16 300 S Hemi
Re: Automatic tranny fluid [Re: v10] #2240640
01/24/17 09:11 PM
01/24/17 09:11 PM
Atlanta
DartGTX Offline
DartGTX  Offline
Atlanta
ATF+4 is perfect for your truck. +3 was replaced because it broke down around 30k. +4 is fill for life. Good luck
Re: Automatic tranny fluid [Re: v10] #2240645
01/24/17 09:17 PM
01/24/17 09:17 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The ATF+4 is good stuff, backwards compatible too.
Re: Automatic tranny fluid [Re: v10] #2240899
01/25/17 08:39 AM
01/25/17 08:39 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
There is a SAE paper on ATF+4 performance versus the three other common trans fluids
http://dastern.torque.net/techdocs/nonlamp/982674.pdf
It is worth noting that ATF+4 will allow clutches to slip earlier.
See Table 10 and Figure 9
This is probably only important when friction materials and clearances are worn.
Other figures in the paper show that ATF+ has an improved life, and has special torque converter "shutter" characteristics.
Re: Automatic tranny fluid [Re: 360view] #2241082
01/25/17 04:38 PM
01/25/17 04:38 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you don't have a lockup converter or OD, you're wasting your money on +4.
