360 Dip Stick #2239698
01/23/17 11:38 AM
01/23/17 11:38 AM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Who makes a dip stick for a 360 engine that works for a engine in a car? I purchased Mr. Gasket P/N 6923 because it came up when I searched for a 360 engine dipstick, but it is for a truck motor as the dipstick handle ends up being almost as high as the carburetor when installed. Don't need a fancy braided one, just a stock replacement one will work.
Re: 360 Dip Stick [Re: DusterKid] #2239768
01/23/17 01:52 PM
01/23/17 01:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Summit has them... I got a chrome one for
my 416.. Mopar also sells them(you can get
it from Summit also)... the LA engines use
the same dip stick(273,318, 340, 360)... you
can see it in this pic
wave
Re: 360 Dip Stick [Re: MR_P_BODY] #2239918
01/23/17 06:07 PM
01/23/17 06:07 PM
Az
Crizila Offline
Crizila  Offline
Az
Went with a "Locar" braided housing in my 33. The braided housing lets you move things around a bit if necessary. Actually had to drill a hole in my A/C mount for the stick handle to stick through.
Fastest 300
