Re: sprung vs unsprung wheelie bars
[Re: 10sec.dart]
#2239191
01/22/17 05:43 PM
01/22/17 05:43 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I like to have the spring on the shorter bars.. long bars I like solid.. when I say long.. 70" and longer.. sounds like you need to move the upper mounting points on your.. just cut them off and move them back farther... now that you know where the wheel sits when its in gear you can move the adjuster to most of the way in.. (about 3/4 of the way in) and reweld the upper mounts
[Re: Monte_Smith]
#2239284
01/22/17 07:06 PM
01/22/17 07:06 PM
dartman366
Mt. Vernon, Ohio
If you actually "use" the bars, meaning they are part of your suspension setup, personally I think sprung bars are useless. If they are just a safety measure, springs are fine. But a 60" bar is fairly long and I don't think should be sprung regardless I agree 100% I use a sprung set that is only there if needed and to also not be as violent as a unsprung set and slam the front end into the pavement, I also don't use mine as a tuning aid just as a safety net in the event it decides to hang em high, which it has done before, I then look into suspension adjustments to tone it down.
[Re: 10sec.dart]
#2239615
01/23/17 02:03 AM
01/23/17 02:03 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I removed the springs on mine and replaced them with pieces of tubing to make them solid. Mine are 66 inch long, and work like they should now that I have enough wieght on the front end to help limit the shock of hitting the bars.
[Re: 10sec.dart]
#2239916
01/23/17 06:04 PM
01/23/17 06:04 PM
Posts: 11,602 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
As stated, a 60" bar shouldn't need to be sprung, especially on a 4 link car with a low CG. But if they are already bought and paid for and the car does get up on them, working with the springs may get the results you want.
I've worked with high CG, quick 60' cars with short bars specified by the rules. The springs provided with the bars went to coil bind instantly and unloaded the tires. Some sourcing and experimenting with springs that had a much higher spring rate made all the difference in the world.
[Re: CMcAllister]
#2240051
01/23/17 09:55 PM
01/23/17 09:55 PM
MR_P_BODY
I have a short WB car and I have a 65" set of wheelie bars with the springs.. the 60' is a 1.19 with a SB N/A 405ci.. runs straight and comes up easy onto the bars.. thats why I like the springs.. it doesnt hit hard to upset the chassis... I have tried putting tubes on them but I didnt like it.. so I went back to springs set fairly snug
