Wiring harness #2238572
01/21/17 07:07 PM
01/21/17 07:07 PM
Wisconsin
71duster414 Offline OP
Wisconsin
Can I please get some names, leads on someone who restores wiring harnesses and can make missing sections?
Thanks!
hoffmanhhr@gmail.com
Re: Wiring harness [Re: 71duster414] #2238622
01/21/17 08:44 PM
01/21/17 08:44 PM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
What year and car? Don't skimp using your old plugs.
Yearone sells factory replacements made by M&H wiring the best plug and play.
Re: Wiring harness [Re: 71duster414] #2238768
01/22/17 12:33 AM
01/22/17 12:33 AM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
I can't answer your question but I agree with Car Nut. I know the harnesses at Year One look expensive. I've done a fair amount of car wiring and while restoring might be an option, "correct" restoration would be expensive also. Having all the different correct color & gauge wires and connectors readily available would be tough unless you go to a pro and that means $$$'s. If you harness is out of the car, getting everything the correct length in the correct position would be near impossible without a jig for your specific car/model/accessories.
That's just my opinion, maybe someone here on Moparts knows of a company that can do a correct, quality job for less.
FYI - If your talking about a dash harness, this would be a good time to bypass that ammeter.
Re: Wiring harness [Re: shorthorse] #2239871
01/23/17 04:59 PM
01/23/17 04:59 PM
Wisconsin
Wisconsin
I'm missing a section for my 71 cuda power window switch. Missing the section between passenger door regulator and the wiring that runs under dash.
Re: Wiring harness [Re: 71duster414] #2239889
01/23/17 05:35 PM
01/23/17 05:35 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
Parts Hound
Tommy White
4225 6 mile road
Racine WI 53402
262-685-8943
