brake swap to new rear end #2238431
01/21/17 02:50 PM
01/21/17 02:50 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Will the stock brakes from an 8 3/4 swap to a new S60 rear?
Re: brake swap to new rear end [Re: frank] #2238440
01/21/17 02:59 PM
01/21/17 02:59 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
it depends on what ends they put on the housing, I got mine with the larger set 20 bearings & had to grind the hole in the backing plate a little to go over the bearing.
Re: brake swap to new rear end [Re: frank] #2238451
01/21/17 03:17 PM
01/21/17 03:17 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
the stock 5 bolt mopar end is 2.875 ID, the larger 5 bolt mopar end is 3.150 ID & has the same bolt pattern as the smaller bearing end, just grind the Backing plate to clear.
Re: brake swap to new rear end [Re: CSK] #2238469
01/21/17 03:47 PM
01/21/17 03:47 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
So with a little grinding on the 8 3/4 backing plate to clear the bearing the rest of the components will fit?
Re: brake swap to new rear end [Re: frank] #2238483
01/21/17 04:05 PM
01/21/17 04:05 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
mine did. if you have the smaller mopar end, no grinding
Re: brake swap to new rear end [Re: frank] #2238487
01/21/17 04:09 PM
01/21/17 04:09 PM
Andrewh Offline
Andrewh  Offline
if I understand what you are asking, all the braking parts hang off the backing plate.
so as long as you can get the backing plate to fit the tubes, the rest is independent of that.
I have a full set of 11 inch hardware just hanging off the backing plates. just unbolted them off the rear and disconnected the brake line and cable.
just haven't taken the time to rip the 10's off to put them on yet.
Re: brake swap to new rear end [Re: Andrewh] #2238502
01/21/17 04:35 PM
01/21/17 04:35 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Copy that. I want to use the brakes from my stock 8 3/4 on the new S60. I know new brakes can be had with the S60 but that's another $400-500 depending on what you go with and there is nothing wrong with the current brakes. Thanks
Re: brake swap to new rear end [Re: CSK] #2238504
01/21/17 04:37 PM
01/21/17 04:37 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
How do you like the S60?
Re: brake swap to new rear end [Re: frank] #2238511
01/21/17 04:48 PM
01/21/17 04:48 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
It works great, very glad I got rid of the 8 3/4,what bearing ends did you get ? who did you order it from?
Re: brake swap to new rear end [Re: frank] #2238513
01/21/17 04:53 PM
01/21/17 04:53 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Re: brake swap to new rear end [Re: frank] #2238593
01/21/17 07:41 PM
01/21/17 07:41 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Put stock 10" brakes from a volare on a new strange s60, after telling them I had loads of stock 10 by 2 1/2 backing plates and hardware. All fit well.
Re: brake swap to new rear end [Re: CSK] #2238598
01/21/17 07:52 PM
01/21/17 07:52 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
I didn't order it yet so not sure on bearing ends. Still have to research that. What did you get? I will order from Strange. Free shipping if ordered by 31 Jan.
