Re: brake swap to new rear end
[Re: frank]
#2238440
01/21/17 02:59 PM
01/21/17 02:59 PM
Posts: 2,858 Pattison Texas
CSK
Pattison Texas
it depends on what ends they put on the housing, I got mine with the larger set 20 bearings & had to grind the hole in the backing plate a little to go over the bearing.
[Re: frank]
#2238451
01/21/17 03:17 PM
01/21/17 03:17 PM
CSK
Pattison Texas
the stock 5 bolt mopar end is 2.875 ID, the larger 5 bolt mopar end is 3.150 ID & has the same bolt pattern as the smaller bearing end, just grind the Backing plate to clear.
[Re: frank]
#2238483
01/21/17 04:05 PM
01/21/17 04:05 PM
CSK
Pattison Texas
mine did. if you have the smaller mopar end, no grinding
[Re: CSK]
#2238504
01/21/17 04:37 PM
01/21/17 04:37 PM
Posts: 2,138 tucson az
frank
tucson az
mine did. if you have the smaller mopar end, no grinding How do you like the S60?
[Re: frank]
#2238511
01/21/17 04:48 PM
01/21/17 04:48 PM
CSK
Pattison Texas
It works great, very glad I got rid of the 8 3/4,what bearing ends did you get ? who did you order it from?
[Re: CSK]
#2238598
01/21/17 07:52 PM
01/21/17 07:52 PM
frank
tucson az
It works great, very glad I got rid of the 8 3/4,what bearing ends did you get ? who did you order it from? I didn't order it yet so not sure on bearing ends. Still have to research that. What did you get? I will order from Strange. Free shipping if ordered by 31 Jan.
