Oil lines for Indy block #2238165
01/20/17 11:06 PM
01/20/17 11:06 PM
WA
JD Dart Offline OP
JD Dart  Offline OP
WA
Will I'm tired of of doing this going to take a break. Aren't Mopars fun
best so far 8.53 @ 158.59 MPH 60'1.240
Re: Oil lines for Indy block [Re: JD Dart] #2238170
01/20/17 11:09 PM
01/20/17 11:09 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
Who's will ?
Re: Oil lines for Indy block [Re: JD Dart] #2238264
01/21/17 02:46 AM
01/21/17 02:46 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
work of art
Re: Oil lines for Indy block [Re: JD Dart] #2238268
01/21/17 03:01 AM
01/21/17 03:01 AM
birdtracker Offline
birdtracker  Offline
Is this necessary for it to survive? birdtracker
Re: Oil lines for Indy block [Re: birdtracker] #2238285
01/21/17 04:38 AM
01/21/17 04:38 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Ok I give up.....what are you trying to do here? Putting pressure to the lifters to oil up the pushrods or EDM oiling for the lifters?
Not my business but if I were you I would remove that deal and open up those drain back holes about double. You might think of drilling a small hole through the bulkhead out to the TC and dist gear area to.
Just a thought....
Re: Oil lines for Indy block [Re: sasquatch] #2238448
01/21/17 03:12 PM
01/21/17 03:12 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
Looks good Jess up
Yes pushrod oiling. B1 heads have 4 drains in the cylinder heads, so I'm guessing most of the oil drains back that way rather than through the valley...?
Re: Oil lines for Indy block [Re: sasquatch] #2238546
01/21/17 05:55 PM
01/21/17 05:55 PM
WA
JD Dart Offline OP
JD Dart  Offline OP
WA
I drilled a big hole up front t/c side that way those small holes might let some oil to drain back and the vacuum pump can pull crankcase pressure up through the big hole up front. All the work was to provide oil to the lifters edm oiling and T&D rocker arms for the new heads this year fingers crossed Al knows the story on that.
Re: Oil lines for Indy block [Re: JD Dart] #2238556
01/21/17 06:22 PM
01/21/17 06:22 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Cool. Nice work.
Todd
Re: Oil lines for Indy block [Re: JD Dart] #2238613
01/21/17 08:33 PM
01/21/17 08:33 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Unfortunately I have to do the same eventually to a KB block that was not done as ordered as well.
Re: Oil lines for Indy block [Re: JD Dart] #2238735
01/21/17 11:36 PM
01/21/17 11:36 PM
NY
challenger451ci Offline
NY
I did something similar with mine. Not a lot of fun, but it works!
Re: Oil lines for Indy block [Re: JD Dart] #2239654
01/23/17 04:20 AM
01/23/17 04:20 AM
Midland,Tx
wyldebill Offline
wyldebill  Offline
Midland,Tx
How and what are you using for an oil restricter?
Re: Oil lines for Indy block [Re: JD Dart] #2239666
01/23/17 05:31 AM
01/23/17 05:31 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
When we ordered the block, didn't order it with lifter oiling. However, now that we will come to drag week, the plan changed. Have to get pushrod oiling upstairs instead of spray bars to survive. Thought about different possibilities with lines similar to thos in the pictures, but then one machined shop volunteered to drill the holes for us. However, they screwed it up a bit, everytime the drill bit pushed throught the lifter bore it guided the drill bit a little. The drivers side went upwards, and the passanger side down, and the two last ones went through to the cam tunnel... Not a big deal though, blocked the channel before them and will oil the two last ones with lines. The lifter bores will be sleeved with about .040"- .060" hole in each sleeve. The lifters will be Jesel. Should have installed an aluminum rod through the lifter bore when drilling and it would propably have turned out just fine, will try that with the next block!
Plynouth VIP '67 TT IC EFI
Re: Oil lines for Indy block [Re: wyldebill] #2239720
01/23/17 12:34 PM
01/23/17 12:34 PM
WA
JD Dart Offline OP
JD Dart  Offline OP
WA
Holley jet I'll start out with 60 and see if that's enough. with the 1/8 pipe fitting in the block just drill out the fitting to 1/4 by 32 thread screw in the jet if it's no enough just change jets
Re: Oil lines for Indy block [Re: JD Dart] #2239781
01/23/17 02:06 PM
01/23/17 02:06 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
IMO you will be fine going way down from a 60 jet. I had a .029" restrictor in my Cuda with no issues.
Re: Oil lines for Indy block [Re: Al_Alguire] #2239818
01/23/17 03:16 PM
01/23/17 03:16 PM
WA
JD Dart Offline OP
JD Dart  Offline OP
WA
.029 per side or total?
Re: Oil lines for Indy block [Re: JD Dart] #2239849
01/23/17 04:13 PM
01/23/17 04:13 PM
NY
NY
I machined the AN fittings down so I could use a Nitrous flare jet. 0.040" feeding each lifter bore. On the stand, mine made 70psi oil pressure with no lifters in it. It made 75-80 with them installed. That's with Crower HIPPO lifters. It makes 75 or so with my boot in it.
Re: Oil lines for Indy block [Re: JD Dart] #2240129
01/23/17 11:31 PM
01/23/17 11:31 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
I had a .065 jet on the main oil feed line to the entire system .
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Oil lines for Indy block [Re: go green] #2240210
01/24/17 01:18 AM
01/24/17 01:18 AM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
At what point are all these oiling mods necessary?
Re: Oil lines for Indy block [Re: JD Dart] #2240255
01/24/17 03:06 AM
01/24/17 03:06 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
At the point where you are starting to have problems with pushrod ends and adjusters or lifters. If you don't have any problems, there is no need for doing things differently.
Re: Oil lines for Indy block [Re: JD Dart] #2240360
01/24/17 12:56 PM
01/24/17 12:56 PM
an8sec70cuda Offline
What heads and/or rocker systems typically need something like this? Looks like a huge PITA. I've had my hands in some fairly serious Mopar builds and never seen one that needed this before.
CHIP
'06 GMC 2500HD LBZ Duramax
