2006 CTD 3500 tuner boxes, which ones? #2235561
01/16/17 08:23 PM
01/16/17 08:23 PM
Cab_Burge Offline OP
My 2006 Ram 3500 single wheel 4WD has a little over 130,000 miles on it now and it is still stock.
I've heard that the newer computer tuner boxes for theses trucks can help on the mileage as well as the power, I drive it empty most of the time, probably 97 to 99 % of the time. I do have a 24 Ft pace enclosed race car trailer loaded going to the races that weighs right at 8600 lbs. on both axles and it adds around 600 lbs. onto the rear axle on the truck, it also removes, shifts, about 300 lbs. from the front axles shock shruggy
I have done a little searching on Summits web site and see several different brands and types of tuner boxes, my question is for those that are using them which ones do you like and which ones don't you like? help
I don't get on this forum very often so please add your comments to help me on this thumbs
Thanks in advance bow
Re: 2006 CTD 3500 tuner boxes, which ones? [Re: Cab_Burge] #2235738
01/17/17 12:27 AM
01/17/17 12:27 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Smarty jr and smarty sr are ok. I will be selling my smarty jr and going with EFI live though. The Jr supposedly adds up to 100 hp. It's definitely making more but I don't know about 100. What's nice about smarty is that it will correct your speedo too.
**Photobucket sucks**
Re: 2006 CTD 3500 tuner boxes, which ones? [Re: 70Cuda383] #2235863
01/17/17 04:16 AM
01/17/17 04:16 AM
My truck was bought in Oregon in July of 2006 so it is considered a border state truck to CA, but I don't really know what that means confused Most of the dodge CTD 4 WHD trucks around here have the exhaust changed and big wheels and tires, mine doesn't. I am planning on changing the tires to the biggest size I can fit on the stock wheels, probably 295x65x17 so being able to correct the speedometer would be nice thumbs
I have seen Bully Dog, Edge, Accel and several others brands out there with different features shruggy I'm not looking to hop it up a bunch, I'm mainly after improving the fuel mileage when empty in town and out on the road help
Re: 2006 CTD 3500 tuner boxes, which ones? [Re: Cab_Burge] #2236404
01/17/17 11:33 PM
01/17/17 11:33 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
more power... better mpg... buy a 2015 or newer smile.
Re: 2006 CTD 3500 tuner boxes, which ones? [Re: Cab_Burge] #2236500
01/18/17 01:35 AM
01/18/17 01:35 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
That's true too. I don't think I gained MPGs. I have to drive like an annoying grandpa to get the overhead lie meter to show 20+, and even then hand calcs show I'm actually at about 17. But, at 8,000 lbs empty, small lift, 4x4 drivetrain, and 35" mud tires on 20" wheels that weigh at least 70, if not 80 lbs; I'm not unhappy. If I cared about mileage, I'd buy a Prius.
Re: 2006 CTD 3500 tuner boxes, which ones? [Re: Cab_Burge] #2236541
01/18/17 02:24 AM
01/18/17 02:24 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
efi live
Re: 2006 CTD 3500 tuner boxes, which ones? [Re: J_BODY] #2236812
01/18/17 05:14 PM
01/18/17 05:14 PM
J, if I could afford a new one I might think about it. I haven't heard that they get better mileage than mine does confused
I have heard form more than one friend and fellow racers that the 2007 and newer CTD trucks get horrible mileage compared to the older 5.9 like mine work
Re: 2006 CTD 3500 tuner boxes, which ones? [Re: Cab_Burge] #2236886
01/18/17 06:51 PM
01/18/17 06:51 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Only if there stock. Lol
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: 2006 CTD 3500 tuner boxes, which ones? [Re: Cab_Burge] #2236989
01/18/17 10:23 PM
01/18/17 10:23 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Cab, for the wheels get the 2015 3500 wheels, I got a set of brand new take offs LT275 / 70x18 32-1/2 tall for $700 wheels tires and caps and they are taller then my 06 wheels( about 5 mph off at 60 now). I talked to a guy on another post, he said the efi gave him mpg in the mid to low 20s and a lot more power, I think six levels, 5 or 6 you'll need a better trans. Tremendous hp and torque, like close to a 1000. But if you keep the foot out of it it gets good millage. I'll try to find his posting and get back to ya
Re: 2006 CTD 3500 tuner boxes, which ones? [Re: Cab_Burge] #2237116
01/19/17 02:20 AM
01/19/17 02:20 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
With the newer 6.7s and the DEF, I think mileage dropped horribly. Have also heard that by 2013 or so, improvements were made and mileage has returned
Re: 2006 CTD 3500 tuner boxes, which ones? [Re: 70Cuda383] #2237181
01/19/17 11:12 AM
01/19/17 11:12 AM
mopar65 Offline
mopar65  Offline
70cuda383 who's EFI tuning are you going to use? If this is your first time using EFI I think you will be amazed at how much smoother the power is compared to smarty. Don't get me wrong I liked the smarty JR I had on my 09 6.7, but it drove so much better with the 500 HP EFI tune I had.
Cab if you really want to try running a tune on your truck, I recommend you call around and ask all the Different EFI tuners there recommendations.
I have not ran any of there tunes but I have heard they are very good at EFI tuning and they are pretty close to your state.
http://atptrucks.com/cummins/dodge-diesel-5-9l-4-5-07/programmers-modules-chips/efilive.html
I have H&S XRT pro on my 2010 4x4 6.7 cummins and with winter fuel and my 35 inch tall tires I have gotten right around 19 MPG. also that is on the max performance tune. But I don't tow heavy with that tune.
Re: 2006 CTD 3500 tuner boxes, which ones? [Re: Cab_Burge] #2237185
01/19/17 11:30 AM
01/19/17 11:30 AM
mopar65 Offline
mopar65  Offline
Here's a pic of my truck.
Re: 2006 CTD 3500 tuner boxes, which ones? [Re: 70Cuda383] #2237459
01/19/17 08:17 PM
01/19/17 08:17 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
The 2013 pickups have DEF. 2007-2012 pickups don't have DEF and their milage is worse because they use lean nox traps for nox reduction, which require regeneration frequently (in addition to the DPF).
Milage typically improves with DEF systems.
Re: 2006 CTD 3500 tuner boxes, which ones? [Re: Blusmbl] #2237481
01/19/17 08:49 PM
01/19/17 08:49 PM
I have kept track of every tank of fuel I've put in this truck, it averages around 14.5 MPG around town and from 20.0 to 21.5 out on the long road trips empty, depending on who's driving whistling My wife gets better fuel mileage than I do, I can't understand that whistling I keep yelling at her to go faster devil shruggy realcrazy grin
Re: 2006 CTD 3500 tuner boxes, which ones? [Re: Cab_Burge] #2239661
01/23/17 05:07 AM
01/23/17 05:07 AM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
I went with Edge as I didn't have gauges. If you already have gauges, there are better choices.
