Re: Non Rallye Dash 68-70 metal brace
[Re: rrunner]
#223602
02/15/09 07:12 PM
02/15/09 07:12 PM
Posts: 3,407 S.E. Florida, USA
rrunner
S.E. Florida, USA
Brace? Do you mean the part of the dash where thelower cluster, switch panel, and pad bolt up?
[Re: rrunner]
#223603
02/15/09 07:30 PM
02/15/09 07:30 PM
340dart4spd
Parts Problem
Parts Problem
YES !!! It is abought same length as speedo cluster..for non rallye cluster
[Re: 340dart4spd ]
#223607
02/15/09 11:37 PM
02/15/09 11:37 PM
Posts: 408 Manhattan, IL
SixPackRT
Manhattan, IL
Is this the part your looking for. I have an extra if you need it. Pm me if so. Scott
70 Coronet RT 440+6 64 Dodge 330 - Future Hemi Clone 17 Challenger Hellcat - Green Go Driver 86 Buick T-Type Turbo V-6
[Re: 68jim]
#223610
02/16/09 12:30 PM
02/16/09 12:30 PM
SixPackRT
Manhattan, IL
Jim, I'm not 100% sure on this but I believe it was just on 70's non-rally. it is actually there to hold the lower dash pad in place with two mounting screws that screw into this bracket. Maybe someone with more knowledge about 68-69 b-bodys can shed some light on this, but I do know the lower dash assembly was completly different in 70, Hope this helps.
70RT, I have tons of pictures of 70 non rally dash pics from my Coronet RT if you need them. let me know, I'm actually in the process of reassembling mine now after restoring each component.
Scott
[Re: SixPackRT]
#223611
02/16/09 12:41 PM
02/16/09 12:41 PM
340dart4spd
Parts Problem
Parts Problem
Scott
That would be great... I am about ready to restore my heater box......
[Re: SixPackRT]
#223613
02/16/09 02:07 PM
02/16/09 02:07 PM
Posts: 1,029 Southeast Virginia
68jim
Southeast Virginia
That would make sense, I'm out working in the garage today and checked out my dash set up. That bracket looks to have some clips to retain hardware pointing up from the lower pad?? It does not appear to be needed for the 68 and probably 69 as well. Learn something new every day...
One more small bit of advice. Try to test all the gauges on the bench before installation into the car. Go with the solid state 5V instrument regulator from RTE. Also, my tach that I tested years ago decided not to work when I got the engine running. I pulled it off from behind the dash (pain in the a$$)and got a kit from RTE as well. It is much happier now!
One more shot of the dash...
[Re: 68jim]
#223614
02/16/09 02:26 PM
02/16/09 02:26 PM
SixPackRT
Manhattan, IL
Thanks Jim, I'll take note on making sure everything functions. I would only like to assemble this dash 1 time and not any more.
70RT, Pics coming via email tonight
Scott
