Non Rallye Dash 68-70 metal brace #223600
02/13/09 06:13 PM
02/13/09 06:13 PM
3
340dart4spd Offline OP
Parts Problem
Parts Problem
3
does anyone have a picture of the metal brace that does between dash cluster and dash frame..... on a non rallye dash 68-70
Re: Non Rallye Dash 68-70 metal brace [Re: 340dart4spd ] #223601
02/14/09 09:50 AM
02/14/09 09:50 AM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Brace? Do you mean the part of the dash where thelower cluster, switch panel, and pad bolt up?
Re: Non Rallye Dash 68-70 metal brace [Re: rrunner] #223602
02/15/09 07:12 PM
02/15/09 07:12 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Re: Non Rallye Dash 68-70 metal brace [Re: rrunner] #223603
02/15/09 07:30 PM
02/15/09 07:30 PM
3
Parts Problem
Parts Problem
3
YES !!! It is abought same length as speedo cluster..for non rallye cluster
Re: Non Rallye Dash 68-70 metal brace [Re: 340dart4spd ] #223604
02/15/09 07:34 PM
02/15/09 07:34 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Thats part of the dash frame.
Re: Non Rallye Dash 68-70 metal brace [Re: rrunner] #223605
02/15/09 10:07 PM
02/15/09 10:07 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I'm not exactly sure what you are looking for. Do you need a picture of the frame itself or the plate that holds the switches? This one is from a 68 Plymouth RR (non rallye)
Re: Non Rallye Dash 68-70 metal brace [Re: 68jim] #223606
02/15/09 10:08 PM
02/15/09 10:08 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Switch plate.
Re: Non Rallye Dash 68-70 metal brace [Re: 340dart4spd ] #223607
02/15/09 11:37 PM
02/15/09 11:37 PM
Manhattan, IL
SixPackRT Offline
SixPackRT  Offline
Manhattan, IL
Is this the part your looking for. I have an extra if you need it. Pm me if so. Scott
70 Coronet RT 440+6
64 Dodge 330 - Future Hemi Clone
17 Challenger Hellcat - Green Go Driver
86 Buick T-Type Turbo V-6
Re: Non Rallye Dash 68-70 metal brace [Re: SixPackRT] #223608
02/16/09 09:31 AM
02/16/09 09:31 AM
3
Parts Problem
Parts Problem
3
thats it... whada know I have one..wasnt sure what it looked like.. I was thinking it was on top of speedo?
Re: Non Rallye Dash 68-70 metal brace [Re: 340dart4spd ] #223609
02/16/09 10:19 AM
02/16/09 10:19 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Scott,
Go figure...It looks like I'm missing that piece or was it something added on for later/different models? - mine is 68 RR.
Re: Non Rallye Dash 68-70 metal brace [Re: 68jim] #223610
02/16/09 12:30 PM
02/16/09 12:30 PM
Manhattan, IL
SixPackRT Offline
SixPackRT  Offline
Manhattan, IL
Jim, I'm not 100% sure on this but I believe it was just on 70's non-rally. it is actually there to hold the lower dash pad in place with two mounting screws that screw into this bracket. Maybe someone with more knowledge about 68-69 b-bodys can shed some light on this, but I do know the lower dash assembly was completly different in 70, Hope this helps.
70RT, I have tons of pictures of 70 non rally dash pics from my Coronet RT if you need them. let me know, I'm actually in the process of reassembling mine now after restoring each component.
Scott
70 Coronet RT 440+6
Re: Non Rallye Dash 68-70 metal brace [Re: SixPackRT] #223611
02/16/09 12:41 PM
02/16/09 12:41 PM
3
Parts Problem
Parts Problem
3
Scott
That would be great... I am about ready to restore my heater box......
Re: Non Rallye Dash 68-70 metal brace [Re: 340dart4spd ] #223612
02/16/09 01:36 PM
02/16/09 01:36 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Not found on 69/68 Plymouths as far as I know. Must be for the 70s and up?
Re: Non Rallye Dash 68-70 metal brace [Re: SixPackRT] #223613
02/16/09 02:07 PM
02/16/09 02:07 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
That would make sense, I'm out working in the garage today and checked out my dash set up. That bracket looks to have some clips to retain hardware pointing up from the lower pad?? It does not appear to be needed for the 68 and probably 69 as well. Learn something new every day...
One more small bit of advice. Try to test all the gauges on the bench before installation into the car. Go with the solid state 5V instrument regulator from RTE. Also, my tach that I tested years ago decided not to work when I got the engine running. I pulled it off from behind the dash (pain in the a$$)and got a kit from RTE as well. It is much happier now!
One more shot of the dash...
Re: Non Rallye Dash 68-70 metal brace [Re: 68jim] #223614
02/16/09 02:26 PM
02/16/09 02:26 PM
Manhattan, IL
SixPackRT Offline
SixPackRT  Offline
Manhattan, IL
Thanks Jim, I'll take note on making sure everything functions. I would only like to assemble this dash 1 time and not any more.
70RT, Pics coming via email tonight
Scott
70 Coronet RT 440+6
