New fasteners on every build #2234264
01/14/17 10:17 PM
01/14/17 10:17 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
I have always used new fasteners on all internal parts every time I build something.I recently got some new ring gear bolts at Summit and was thinking I just changed them 5 years ago when I put the 3.54's in.Do you guys change ring gear bolts,flywheel bolts,pressure plate bolts etc. when you have them apart? I just think it's just cheap insurance to use new top quality fasteners when you have it apart shruggy
Now I know an aircraft tech and he says sometimes it's better to know what you have instead of using new.
Do you guys use new bolts every time you change out rotating high stress parts like flywheels and ring gears?
Gus beer
64 Plymouth Savoy
Dana 60
Re: New fasteners on every build [Re: fourgearsavoy] #2234280
01/14/17 10:35 PM
01/14/17 10:35 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
No.
Old parts have proven themselves to be good.
New parts haven't yet...
Re: New fasteners on every build [Re: BigBlockMopar] #2234281
01/14/17 10:37 PM
01/14/17 10:37 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
No, I don't trust fasteners anymore, how do you know for sure where they are made? The original fasteners worked just fine, if they still look good I use them. twocents
JB Rhinehart, Realist
A-Body's RULE!
Re: New fasteners on every build [Re: fourgearsavoy] #2234287
01/14/17 10:41 PM
01/14/17 10:41 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Gus beer
I toss any critical fastener previously used, be it engine, trans, rear end, suspension, braking system, a fastener can only survive just so many stretch, stress, along with heat cycles before failure...I generally prefer to increase the grade/tensile of the fastener if I can when replacing it
Re: New fasteners on every build [Re: fourgearsavoy] #2234299
01/14/17 10:55 PM
01/14/17 10:55 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
On this topic, I would say one of the most re torqued, without at least a torque wrench, possibly over tightened with an impact, cyclically stressed, non redundant, critical fasteners, is also one of the least replaced items on a high performance car, the wheel studs. work
Re: New fasteners on every build [Re: Rhinodart] #2234348
01/14/17 11:50 PM
01/14/17 11:50 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
ARP
Don't be the exception.
Re: New fasteners on every build [Re: fourgearsavoy] #2234375
01/15/17 12:24 AM
01/15/17 12:24 AM
Cab_Burge Online work
Cab_Burge  Online Work
Gus, if it ain't broken, don't fix it tsk twocents
if marginal or suspect replace it with better parts up
Re: New fasteners on every build [Re: Cab_Burge] #2234385
01/15/17 12:35 AM
01/15/17 12:35 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
New ARP bolts inside the engine. Other less important stuff is replaced if it shows wear and tear and looks suspect.
My last engine rebuild was based from an engine that came from a van that burned to the ground so I bought all new fasteners throughout.
Re: New fasteners on every build [Re: fourgearsavoy] #2234638
01/15/17 02:05 PM
01/15/17 02:05 PM
AndyF Offline
AndyF  Offline
I don't replace bolts unless I see a problem with them. I throw bolts and nuts away if they have any damage but otherwise just clean them and put them back into service. Bolts are basically springs and we reuse springs over and over until they get damaged or lose tension.
Re: New fasteners on every build [Re: AndyF] #2235125
01/16/17 02:34 AM
01/16/17 02:34 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Gus, I have changed gears in my Dana at least 5 times if not more. I am going to change them again and this time I will change out all of the bolts. May not need to but after this many times why take the chance - shruggy
Re: New fasteners on every build [Re: fourgearsavoy] #2235137
01/16/17 02:45 AM
01/16/17 02:45 AM
Omaha Nebraska
Brian_wo Offline
Brian_wo  Offline
Omaha Nebraska
Never
who is that guy?
Re: New fasteners on every build [Re: DAYCLONA] #2235162
01/16/17 04:04 AM
01/16/17 04:04 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Absolutely spot-on...
Re: New fasteners on every build [Re: RSNOMO] #2235178
01/16/17 10:09 AM
01/16/17 10:09 AM
robertop Offline
robertop  Offline
That's what most people believe. Without any metallurgical background, of course...
Re: New fasteners on every build [Re: robertop] #2235235
01/16/17 12:49 PM
01/16/17 12:49 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Actually I have 35+ years experience in a metallurgical/engineering field
Re: New fasteners on every build [Re: fourgearsavoy] #2235315
01/16/17 02:37 PM
01/16/17 02:37 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Send me all your wore out bolts, I'll get rid of them for you.
Re: New fasteners on every build [Re: robertop] #2235415
01/16/17 04:50 PM
01/16/17 04:50 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Which is the exact reason why I agreed...
Re: New fasteners on every build [Re: DAYCLONA] #2236576
01/18/17 09:06 AM
01/18/17 09:06 AM
robertop Offline
robertop  Offline
Ok, so explain better your statement. By the way I was the senior metallurgist in one of the major independent test labs in the south for 34 years, so we speak the same language.
Re: New fasteners on every build [Re: robertop] #2236836
01/18/17 05:35 PM
01/18/17 05:35 PM
Rittman Ohio
Rittman Ohio
So in your expert opinion is a visual inspection all that is needed to reject a fastener? I have been a technician for over 30 years and have rebuilt probably 100 engines of all types. I always replace head bolts and main cap bolts on an engine that has been in service for 50 years and is going to be whooped on repeatedly. On regular passenger car engines that have come in to the dealership that need a rebuild due to head gasket failure I always replace the head bolts. What is your professional opinion on reusing plastic region stretch bolts.
I've been doing a lot of rebuilds lately and sometimes the head bolts don't seem to pull that 90 degree turn all the same, some feel like they pull down easier than the others. The bolts are too long to fit my calipers so I have never tried to measure them for comparison.
Gus beer
64 Plymouth Savoy
Dana 60
Re: New fasteners on every build [Re: fourgearsavoy] #2237070
01/19/17 01:03 AM
01/19/17 01:03 AM
robertop Offline
robertop  Offline
Obviously if a bolt has stretched or is corroded, bent, or visually damaged, by all means throw it away. If you are not sure, you can measure the hardness, check its structure and grade (destructive tests, in general) and chemistry to see where you are. And as far as fatigue one must know if the stress on it is in the fatigue range, and so is temperature, that has to be high enough to affect the metal. All of these tests make sense in a lab, but practically it's much cheaper and easier to use new fasteners, so I don't have a problem with that.
Re: New fasteners on every build [Re: robertop] #2237187
01/19/17 11:33 AM
01/19/17 11:33 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I look at it this way, there are certain fasteners in an engine that, if they fail, the cost to repair far outweighs the cost to initially replace. Rod and main bolts come to mind. Head bolts don't quite fall into that category for me but the thought of hanging over a fender wrasslin' a head off because the headgasket failed due to a soft headbolt puts those into the replace category for me.
The rest, not so much.
