BDS intake Modman style #2234285
01/14/17 10:39 PM
01/14/17 10:39 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Spacer from the top of the blower will fit the same on the intake,Home made Modman
Re: BDS intake Modman style [Re: Clanton] #2234320
01/14/17 11:14 PM
01/14/17 11:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Looks good.. pretty simple build...
and I still like the blow off in there
but isnt needed.. but still good
EDIT
I like that its eating your wrench... LOL
wave
Re: BDS intake Modman style [Re: Clanton] #2234326
01/14/17 11:28 PM
01/14/17 11:28 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks!I think it could use some plenum like 1" but other than that.
Re: BDS intake Modman style [Re: Clanton] #2234327
01/14/17 11:29 PM
01/14/17 11:29 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I'd make it a plate that bolts to the blower mounting bolts
Re: BDS intake Modman style [Re: Clanton] #2234334
01/14/17 11:35 PM
01/14/17 11:35 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
12.5 x 15.5" I am hoping 1/2" will do[onlinemetals.com]
Re: BDS intake Modman style [Re: FastmOp] #2234338
01/14/17 11:38 PM
01/14/17 11:38 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The carb adapter has 6 x3/8 bolts bolting in the center and would seal best but is another option
Re: BDS intake Modman style [Re: Clanton] #2234357
01/14/17 11:58 PM
01/14/17 11:58 PM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
The outer portion would be a killer warm up plug tray. Lol. Pretty cool build. I've often wondered if anyone has made Na use of a blower manifold.
Re: BDS intake Modman style [Re: Clanton] #2234373
01/15/17 12:20 AM
01/15/17 12:20 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I'd hate to drill the adapter holes into the intake then plan on putting the blower back on at a later date. I'd use the big plate, 1/2 inch thick and seal it around the perimeter. There's nothing to leak. I think it will work fine.
Re: BDS intake Modman style [Re: Clanton] #2234561
01/15/17 12:36 PM
01/15/17 12:36 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks for your help so far.Here is the base of the carb adapter showing a nice taper into the plenum
The side linkage to the carbs will work on a horizontal plane mounted on bar stock bolted to the blower studs on a pivot
Re: BDS intake Modman style [Re: Clanton] #2234567
01/15/17 12:41 PM
01/15/17 12:41 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
My wife would ban me from the kitchen forever if I had all that sitting on her counter top beside the sink. LMAO
Re: BDS intake Modman style [Re: Dodgeguy101] #2234686
01/15/17 02:54 PM
01/15/17 02:54 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I put it there for lighting to take the pic
Re: BDS intake Modman style [Re: Clanton] #2234783
01/15/17 05:41 PM
01/15/17 05:41 PM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
Great job. Very neat idea.
Re: BDS intake Modman style [Re: Clanton] #2234789
01/15/17 05:52 PM
01/15/17 05:52 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The plenum volume is 168" but it is so shallow I think it will hurt cylinder fill and plenum volume is about the only thing I can adjust.
Thanks Killermopar.
Re: BDS intake Modman style [Re: Clanton] #2234795
01/15/17 06:07 PM
01/15/17 06:07 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I think my plate idea with the adapter bolted to IT is the best option.
Re: BDS intake Modman style [Re: FastmOp] #2234863
01/15/17 07:29 PM
01/15/17 07:29 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thank you,certainly the easiest,What are the opinions of the Modman intake from Indy?
Re: BDS intake Modman style [Re: Clanton] #2234928
01/15/17 09:54 PM
01/15/17 09:54 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I guess I'm just too much of an "inside the box" thinker.
Rather than drill extra holes in my expensive blower manifold, I'd just try and find a used TR to put my two carbs on.
That being said...... I'll still be interested to hear how it works out.
Re: BDS intake Modman style [Re: fast68plymouth] #2234973
01/15/17 11:15 PM
01/15/17 11:15 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The whole point really is to see if the BDS will work like a Modman intake might so I am not out anything but time and 30$ for an aluminum plate that I can make other use of.
Re: BDS intake Modman style [Re: Clanton] #2234984
01/15/17 11:26 PM
01/15/17 11:26 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Re: BDS intake Modman style [Re: Clanton] #2235072
01/16/17 01:15 AM
01/16/17 01:15 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
I agree,I wouldn't drill the BDS manifold.No personal experience with a ModMan intake,but I've read it's best as a blower manifold in most applications. Guessing the open plenum is hard to balance cylinder fill with just a carb or carbs.I'm sure the level of this varies with the carb/engine combo though.
Re: BDS intake Modman style [Re: Clanton] #2235076
01/16/17 01:20 AM
01/16/17 01:20 AM
Ohio
lockjaw-express Offline
Ohio
I was told that the Modman was best with two carbs, and lousy with one. I can confirm that, however I bought the EFI Modman for my 440, and was told that it works great with one or two throttle bodies.
