Re: BDS intake Modman style
[Re: Clanton]
#2234320
01/14/17 11:14 PM
01/14/17 11:14 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Looks good.. pretty simple build... and I still like the blow off in there but isnt needed.. but still good EDIT I like that its eating your wrench... LOL
[Re: FastmOp]
#2234338
01/14/17 11:38 PM
01/14/17 11:38 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I'd make it a plate that bolts to the blower mounting bolts The carb adapter has 6 x3/8 bolts bolting in the center and would seal best but is another option
[Re: Clanton]
#2234357
01/14/17 11:58 PM
01/14/17 11:58 PM
Posts: 1,308 Spencer NY
killermopar
Spencer NY
The outer portion would be a killer warm up plug tray. Lol. Pretty cool build. I've often wondered if anyone has made Na use of a blower manifold.
[Re: Dodgeguy101]
#2234686
01/15/17 02:54 PM
01/15/17 02:54 PM
Clanton
northern,Ohio,USA
My wife would ban me from the kitchen forever if I had all that sitting on her counter top beside the sink. LMAO I put it there for lighting to take the pic
[Re: FastmOp]
#2234863
01/15/17 07:29 PM
01/15/17 07:29 PM
Clanton
northern,Ohio,USA
I think my plate idea with the adapter bolted to IT is the best option. Thank you,certainly the easiest,What are the opinions of the Modman intake from Indy?
[Re: Clanton]
#2234928
01/15/17 09:54 PM
01/15/17 09:54 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I guess I'm just too much of an "inside the box" thinker.
Rather than drill extra holes in my expensive blower manifold, I'd just try and find a used TR to put my two carbs on. That being said...... I'll still be interested to hear how it works out.
[Re: fast68plymouth]
#2234973
01/15/17 11:15 PM
01/15/17 11:15 PM
Clanton
northern,Ohio,USA
Rather than drill extra holes in my expensive blower manifold, I'd just try and find a used TR to put my two carbs on. That being said...... I'll still be interested to hear how it works out. The whole point really is to see if the BDS will work like a Modman intake might so I am not out anything but time and 30$ for an aluminum plate that I can make other use of.
[Re: Clanton]
#2235072
01/16/17 01:15 AM
01/16/17 01:15 AM
Posts: 1,881 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
I think my plate idea with the adapter bolted to IT is the best option. Thank you,certainly the easiest,What are the opinions of the Modman intake from Indy? I agree,I wouldn't drill the BDS manifold.No personal experience with a ModMan intake,but I've read it's best as a blower manifold in most applications. Guessing the open plenum is hard to balance cylinder fill with just a carb or carbs.I'm sure the level of this varies with the carb/engine combo though.
