Re: Hemi Rockers
[Re: 71birdJ68]
#2233285
01/13/17 01:52 AM
01/13/17 01:52 AM
Posts: 7,497 Minnesota
Hemi_Joel
Minnesota
The oil for the roller tip comes from a hole in the rocker right at the shaft. So it has to squirt all the way out to the tip. When you start it cold,the oil does not get out there until it thins out. I burned up a bunch of rocker tips before I switched to 5W30 oil, and made the groove in the #4 cam journal larger to provide more oil volume to the rockers. The Stage V rockers from FHO have pressure oiling right out to the roller. So they are better. Below is a picture I took with the engine running when I was diagnosing the issue with the MP rockers. It captures the little squirt of oil that is intended to oil the roller. (see red arrow)
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Hemi Rockers
[Re: 71birdJ68]
#2233289
01/13/17 01:57 AM
01/13/17 01:57 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
I just bought a set of Stage V rockers and they did not have the oiling holes. We drilled the holes and grooved the bushings. I was kind of disappointed spending 1200.00 for rockers and had to drill the holes.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
Re: Hemi Rockers
[Re: 71birdJ68]
#2233405
01/13/17 11:07 AM
01/13/17 11:07 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
I have DLI roller rockers on mine which look just like the ones in HemiJoel's pic. No issues in 10 years.
Re: Hemi Rockers
[Re: 71birdJ68]
#2233981
01/14/17 01:20 PM
01/14/17 01:20 PM
Posts: 12,589 Great Neck,LI,new york
hemi-itis
an8sec70cuda and Hemi Joel have the same as mine.I think they are DLI that were sold through direct Connection.Joel,would you clarify where the oil hole is?? My comp lifters have PR oiling ability,so I sent oil up the exhaust side only.
Re: Hemi Rockers
[Re: 71birdJ68]
#2234014
01/14/17 02:34 PM
01/14/17 02:34 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Just curious.......do the oem rockers have a "better"(different ?) way of oiling the valve tip/spring? Or do they also rely on an indirect splash of oil coming from pretty far away to get the job done......like it appears to be with the DLI rockers?
Re: Hemi Rockers
[Re: 71birdJ68]
#2234931
01/15/17 10:00 PM
01/15/17 10:00 PM
fast68plymouth
So. Burlington, Vt.
I looked through some pics of the OE rockers and didnt see any holes where they are oiling the valve side of the rocker. At least there didn't appear to be any from what I could see.
Looks like the valve tip/guide/spring all got oiled by splash/mist.
Re: Hemi Rockers
[Re: 71birdJ68]
#2235601
01/16/17 09:23 PM
01/16/17 09:23 PM
fast68plymouth
So. Burlington, Vt.
Joel, how about the OE exhaust rocker...... Is there a hole on the spring side of those as well?
Looks like the pushrod oiling hole on the DLI exhaust rocker is pretty far away from the pushrod.
Re: Hemi Rockers
[Re: RAY1969CARS]
#2238246
01/21/17 01:47 AM
01/21/17 01:47 AM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
I made every dli roller rocker arms from 1999 to 2007 I had forgoten you had worked at DLI. It's been awhile since you posted those pics.
