Hemi Rockers #2233257
01/13/17 01:17 AM
01/13/17 01:17 AM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
I have Mopar Performance ( I think ) roller tip rockers in my Hemi, wondering if they are any good, reliable?
Re: Hemi Rockers [Re: 71birdJ68] #2233272
01/13/17 01:40 AM
01/13/17 01:40 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Do they look like these?
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Hemi Rockers [Re: 71birdJ68] #2233285
01/13/17 01:52 AM
01/13/17 01:52 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
The oil for the roller tip comes from a hole in the rocker right at the shaft. So it has to squirt all the way out to the tip. When you start it cold,the oil does not get out there until it thins out. I burned up a bunch of rocker tips before I switched to 5W30 oil, and made the groove in the #4 cam journal larger to provide more oil volume to the rockers.
The Stage V rockers from FHO have pressure oiling right out to the roller. So they are better.
Below is a picture I took with the engine running when I was diagnosing the issue with the MP rockers. It captures the little squirt of oil that is intended to oil the roller. (see red arrow)
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Hemi Rockers [Re: 71birdJ68] #2233289
01/13/17 01:57 AM
01/13/17 01:57 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I just bought a set of Stage V rockers and they did not have the oiling holes. We drilled the holes and grooved the bushings. I was kind of disappointed spending 1200.00 for rockers and had to drill the holes.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Hemi Rockers [Re: 71birdJ68] #2233311
01/13/17 02:35 AM
01/13/17 02:35 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
If you buy the Stage V from Tim Banning at For Hemis Only, they will have the oil holes direct to the roller. He has them made special that way.
Re: Hemi Rockers [Re: hemi-itis] #2233345
01/13/17 03:12 AM
01/13/17 03:12 AM
Morristown Tn.
Morristown Tn.
Like what? No picture
Re: Hemi Rockers [Re: 71birdJ68] #2233398
01/13/17 10:54 AM
01/13/17 10:54 AM
moparmarks Offline
moparmarks  Offline
Ok I got them from Hemi Parts King.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Hemi Rockers [Re: Hemi_Joel] #2233402
01/13/17 10:59 AM
01/13/17 10:59 AM
Morristown Tn.
Morristown Tn.
Mine doesn't look like that.
Re: Hemi Rockers [Re: 71birdJ68] #2233405
01/13/17 11:07 AM
01/13/17 11:07 AM
an8sec70cuda Offline
I have DLI roller rockers on mine which look just like the ones in HemiJoel's pic. No issues in 10 years. twocents
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Hemi Rockers [Re: hemi-itis] #2233715
01/13/17 09:14 PM
01/13/17 09:14 PM
Morristown Tn.
Morristown Tn.
Yes, Hemi-itis they look pretty much like yours. Guess what I found today...on 4 of the exhaust rockers there weren't any oil squirt holes for the push rod cups.
Re: Hemi Rockers [Re: 71birdJ68] #2233981
01/14/17 01:20 PM
01/14/17 01:20 PM
hemi-itis Offline
hemi-itis  Offline
an8sec70cuda and Hemi Joel have the same as mine.I think they are DLI that were sold through direct Connection.Joel,would you clarify where the oil hole is?? My comp lifters have PR oiling ability,so I sent oil up the exhaust side only.
Re: Hemi Rockers [Re: 71birdJ68] #2234014
01/14/17 02:34 PM
01/14/17 02:34 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Just curious.......do the oem rockers have a "better"(different ?) way of oiling the valve tip/spring?
Or do they also rely on an indirect splash of oil coming from pretty far away to get the job done......like it appears to be with the DLI rockers?
Re: Hemi Rockers [Re: fast68plymouth] #2234278
01/14/17 10:32 PM
01/14/17 10:32 PM
Morristown Tn.
Morristown Tn.
I think that the OEM oiled directly at the tip.
Re: Hemi Rockers [Re: 71birdJ68] #2234931
01/15/17 10:00 PM
01/15/17 10:00 PM
So. Burlington, Vt.
So. Burlington, Vt.
I looked through some pics of the OE rockers and didnt see any holes where they are oiling the valve side of the rocker.
At least there didn't appear to be any from what I could see.
Looks like the valve tip/guide/spring all got oiled by splash/mist.
Re: Hemi Rockers [Re: 71birdJ68] #2235559
01/16/17 08:18 PM
01/16/17 08:18 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Here are some pics showing the oil holes on stock rockers and mopar performance/landy roller rockers.
Hopefully this helps, Joel
Re: Hemi Rockers [Re: 71birdJ68] #2235601
01/16/17 09:23 PM
01/16/17 09:23 PM
So. Burlington, Vt.
So. Burlington, Vt.
Joel, how about the OE exhaust rocker...... Is there a hole on the spring side of those as well?
Looks like the pushrod oiling hole on the DLI exhaust rocker is pretty far away from the pushrod.
Re: Hemi Rockers [Re: 71birdJ68] #2235688
01/16/17 11:37 PM
01/16/17 11:37 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Somehow the pictures got mixed up. Here is the stock exhaust tip.
Re: Hemi Rockers [Re: Hemi_Joel] #2238148
01/20/17 10:25 PM
01/20/17 10:25 PM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
I made every dli roller rocker arms from 1999 to 2007
Re: Hemi Rockers [Re: 71birdJ68] #2238150
01/20/17 10:32 PM
01/20/17 10:32 PM
So. Burlington, Vt.
So. Burlington, Vt.
Wow!!
That's a nice piece of trivia right there!!
Re: Hemi Rockers [Re: RAY1969CARS] #2238246
01/21/17 01:47 AM
01/21/17 01:47 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I had forgoten you had worked at DLI.
It's been awhile since you posted those pics.
