Has anyone used both Jeep SRT manifolds in restomod? #2124172
08/03/16 05:49 PM
08/03/16 05:49 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
I know the LX/LC platform SRT headers won't work....I have been reading about the hemi swap for weeks now and I can't remember where I saw it, but some guys said they used Jeep manifolds but they don't specify whether they were 5.7 Manifolds (not interested in this even if they do fit) or Jeep SRT manifolds. Has anyone used the SRT Jeep manifolds in their restomod and what transmission/suspension/header setup did you use? Thanks
I am researching for this fairly basic build: 1968 Roadrunner with 6.1L Gen 3 hemi, 4 speed 833, stock k member with torsion bars, etc.
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Roadrunner w/ 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: Has anyone used both Jeep SRT manifolds in restomod? [Re: 70B5Cuda] #2124253
08/03/16 07:37 PM
08/03/16 07:37 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
We tried. They dont fit an A Body...the angle is all wrong.
Just do the TTI's. I had to ding mine a bit...but its not a huge deal.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Has anyone used both Jeep SRT manifolds in restomod? [Re: 70B5Cuda] #2124376
08/03/16 10:24 PM
08/03/16 10:24 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
The 6.4 Jeep manifolds are a nice swoopy cast manifold
Re: Has anyone used both Jeep SRT manifolds in restomod? [Re: AlexP] #2124429
08/03/16 11:06 PM
08/03/16 11:06 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Did you try to Jeep SRT manifolds on your roadrunner?
Re: Has anyone used both Jeep SRT manifolds in restomod? [Re: 70B5Cuda] #2124454
08/03/16 11:37 PM
08/03/16 11:37 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
No, based on wades car they agreed they would have run into the firewall. I really wanted a mid length header because I've got my car low. I even tried a 5.7 eagle cast iron unshrouded unit and it didn't work.
Re: Has anyone used both Jeep SRT manifolds in restomod? [Re: 70B5Cuda] #2124576
08/04/16 01:51 AM
08/04/16 01:51 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
That's disappointing. I found a pair of Jeep SRT manifolds for cheap....I also have a set of the LX JBA Shorties I may try but they probably won't fit either.
Re: Has anyone used both Jeep SRT manifolds in restomod? [Re: 70B5Cuda] #2124668
08/04/16 10:17 AM
08/04/16 10:17 AM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
My Ideal set up would have been a middy header that doesn't have the collector parallel to the floor.
TTI makes them for the B/RB but not a 6.1...
Incidentally I raised the car anyway due to needing clearance for other things, so the Long tube TTI headers will work even better.
Re: Has anyone used both Jeep SRT manifolds in restomod? [Re: 70B5Cuda] #2130930
08/12/16 10:31 AM
08/12/16 10:31 AM
gregsdart Online content
gregsdart  Online Content
I have Jeep SRT8 stainless steel factory manifolds test fit in a 65 Dart on a 5.7 block. They will work, although I am going with coil over front shock/springs to gain pipe clearance.
Re: Has anyone used both Jeep SRT manifolds in restomod? [Re: gregsdart] #2233366
01/13/17 05:09 AM
01/13/17 05:09 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I used the srt jeep manifolds, I don't remember how to post a picture
Re: Has anyone used both Jeep SRT manifolds in restomod? [Re: 70blackfish] #2233794
01/13/17 11:02 PM
01/13/17 11:02 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
And they worked fine in an E body?!?
Re: Has anyone used both Jeep SRT manifolds in restomod? [Re: 70B5Cuda] #2326946
06/26/17 01:43 PM
06/26/17 01:43 PM
Detroit, MI
kz5rt2 Offline
kz5rt2  Offline
Detroit, MI
Just curious what you are using out there to make the 833 bolt up to the 6.1?
Re: Has anyone used both Jeep SRT manifolds in restomod? [Re: 70blackfish] #2327055
06/26/17 05:49 PM
06/26/17 05:49 PM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
Hit 'reply' then click on the 4th box from the left above the reply box... square image with 3 dots and the right top corner turned over.
Re: Has anyone used both Jeep SRT manifolds in restomod? [Re: kz5rt2] #2327311
06/27/17 12:52 AM
06/27/17 12:52 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
They are identical to a small block except the Gen III has a top center bolt not used on a small block. The pilot on the 833 is a tad long for the Gen III pilot hole so you can either drill the crank deeper or shorter input on 833. No big deal, use a 130 tooth Gen III flywheel and a stock starter even works.
Mopar to the bone!!!
Re: Has anyone used both Jeep SRT manifolds in restomod? [Re: 70B5Cuda] #2330661
07/03/17 01:19 PM
07/03/17 01:19 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
in my 69 c10 truck...
Re: Has anyone used both Jeep SRT manifolds in restomod? [Re: 70B5Cuda] #2331398
07/04/17 02:54 PM
07/04/17 02:54 PM
Shingle Springs Ca
haddixj Offline
haddixj  Offline
Shingle Springs Ca
what flywheel is it? I am doing the same swap above in my dads 69 GTX and am having a hard time finding the exact flywheel. I thought it needed an offset into it? I have a part number for Mcleod but it doesn't work anymore, I found the one on Brewers and Mopar website but still doesn't say for sure that is what it will accomplish.
Does just a standard 130 tooth steel flywheel work with the 833 trans? We are running the factory bell housing and want to run the factory Z bar linkage if we can. Were you able to?
70 duster 25.1E,73 barracuda, 70 gran coupe, 71 cuda
