E-Body Steering Column Part 4 (Final Assembly) #2231729
01/10/17 05:10 PM
01/10/17 05:10 PM
Vancouver, WA
Cuda Cody Offline OP
Vancouver, WA
Part 4 of 4 of a "How-To" series about E-Body Steering columns. In this final Video we cover how to assemble the E-Body Steering column.
1970 Challenger T/A 4-Speed
1970 Challenger T/A Auto
1970 Challenger R/T Auto
1970 Challenger Auto
1970 Challenger RT 440+6 4-Speed
1970 Hemi Challenger 4-Speed
1970 Hemi Cuda 4-Speed
1971 Cuda Auto
1971 Cuda 4-Speed
LOOKING to BUY 1970 & 1971 E Body J, V and R Code project cars
Re: E-Body Steering Column Part 4 (Final Assembly) [Re: Cuda Cody] #2231828
01/10/17 08:22 PM
01/10/17 08:22 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Great stuf Cody
Re: E-Body Steering Column Part 4 (Final Assembly) [Re: Cuda Cody] #2231846
01/10/17 09:06 PM
01/10/17 09:06 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Cody, how about a video on how to repair a column shaft that has been collapsed. And the correct lengths that the different columns should be.
Re: E-Body Steering Column Part 4 (Final Assembly) [Re: Cuda Cody] #2231862
01/10/17 09:34 PM
01/10/17 09:34 PM
WA
tman Offline
tman  Offline
WA
Awesome presentation!
Re: E-Body Steering Column Part 4 (Final Assembly) [Re: Cuda Cody] #2231863
01/10/17 09:36 PM
01/10/17 09:36 PM
Vancouver, WA
Vancouver, WA
E-Body shafts only have 2 lengths (manual & power steering), but the difference in length is in the lower half. So I think they all get repaired to the same length. It's measured from the top of the threaded end to the first of the plastic pins. I could double check some un-collapsed shafts, but I think it's like 16 3/8" or around there.
Mopar sold a kit to repair the collapsed steering column shafts. It did not replace the pins, instead it glues the shafts together so they would still collapse if in an accident. So that might be a good option to try first. If I had a collapsed shaft I could play around and find a good glue that would hold up to about the same impact strength as the original plastic pins.
[img]http://forum.e-bodies.org/index.php?action=dlattach;topic=199.0;attach=1520;image[/img]
1971 Cuda Auto
1971 Cuda 4-Speed
Re: E-Body Steering Column Part 4 (Final Assembly) [Re: Cuda Cody] #2231953
01/10/17 11:34 PM
01/10/17 11:34 PM
Washougal,Wa
Dodge Offline
Dodge  Offline
Washougal,Wa
Very good info as always up
Stand behind your word
Re: E-Body Steering Column Part 4 (Final Assembly) [Re: Cuda Cody] #2231983
01/11/17 12:08 AM
01/11/17 12:08 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Cody: Was wondering if you had considered combining access these videos into a single thread and posting in the Questions and Answers section.
My observation over the years has been that it has far more viewers than does The Restoration 12 section.
I suspect that many members who might benefit form your fine effort may completely miss this.
I was also thinking that there could perhaps be another section created on the forum, where how to videos and other such instructive teachings might be archived.
I have stumbled over many, but a separate "Go To" could prove helpful,,,,kind of a super sticky section.
Re: E-Body Steering Column Part 4 (Final Assembly) [Re: Sxrxrnr] #2232001
01/11/17 12:25 AM
01/11/17 12:25 AM
Washougal,Wa
Dodge Offline
Dodge  Offline
Washougal,Wa
A list, so you could go down the list instead of searching.How to restore this part, or parts restoration section that more than one person could post there way to restore the same part. In that same post and each post, the venders could list that they sell a part needed in the restoration and maybe even list the part # and price.
Re: E-Body Steering Column Part 4 (Final Assembly) [Re: Cuda Cody] #2232029
01/11/17 12:57 AM
01/11/17 12:57 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Cody, actually mine is a 71 B body. But the procedure would be the same. I have seen that repair kit, but finding that now a days I guess would be impossible. I took mine apart and the inner tube has a milled slot the the plastic filled along with the hole. I trie shot glue, but that didn't work very well. Just wondering if there would be a better option.
Re: E-Body Steering Column Part 4 (Final Assembly) [Re: 71birdJ68] #2232105
01/11/17 03:47 AM
01/11/17 03:47 AM
Vancouver, WA
Vancouver, WA
Well, there's gotta be something out there that would work, but I'm just not sure without doing some testing. With today's 2 part epoxy and glues it would just come down to testing a couple different ones. I would look Lords Adhesives. Most of them might be too strong, but if you contact them or go to a local supplier they might have something that will work. Don't give up. I know you can find a solution. smile
http://www.lord.com/products-and-solutions/brands/lord---adhesives
1971 Cuda Auto
1971 Cuda 4-Speed
Re: E-Body Steering Column Part 4 (Final Assembly) [Re: Sxrxrnr] #2232121
01/11/17 04:31 AM
01/11/17 04:31 AM
Vancouver, WA
Vancouver, WA
That's a good idea. I'll put them all in one post over there.
As for Sections on the Forum, I think that's a good idea. But not sure who does those things?
1971 Cuda Auto
1971 Cuda 4-Speed
Re: E-Body Steering Column Part 4 (Final Assembly) [Re: Cuda Cody] #2233928
01/14/17 09:45 AM
01/14/17 09:45 AM
Slidell, LA
Plum440 Offline
Plum440  Offline
Slidell, LA
Great video! Thank you.
70 Challenger, 440, 4-speed, pLuM cRaZy
71 VW Super Beetle Convertible, Lemon Yellow
A couple of Jeeps…
Re: E-Body Steering Column Part 4 (Final Assembly) [Re: Plum440] #2233998
01/14/17 02:07 PM
01/14/17 02:07 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
What kind of grease are you using for the final assembly and your coupler? Very, very helpful videos Cody. Thank you again for taking the time to share your procedures with us. Much appreciated. Eddie
Re: E-Body Steering Column Part 4 (Final Assembly) [Re: Cuda Cody] #2234259
01/14/17 10:07 PM
01/14/17 10:07 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
Thanks for the videos
Re: E-Body Steering Column Part 4 (Final Assembly) [Re: EL5 71] #2234503
01/15/17 06:15 AM
01/15/17 06:15 AM
Vancouver, WA
Vancouver, WA
I use synthetic wheel bearing grease, but any good grease should work well.
1971 Cuda Auto
1971 Cuda 4-Speed
Re: E-Body Steering Column Part 4 (Final Assembly) [Re: Cuda Cody] #2234557
01/15/17 12:19 PM
01/15/17 12:19 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
I don`t have a e body but my lock plate pin was solid. Did you replace it with a roll pin or is e body or other years different?
Re: E-Body Steering Column Part 4 (Final Assembly) [Re: mopars4ever] #2234737
01/15/17 04:11 PM
01/15/17 04:11 PM
Vancouver, WA
Vancouver, WA
I reuse the original pins. Then put the cover cap back over them to hold them in.
1971 Cuda Auto
1971 Cuda 4-Speed
