1970 Challenger 383 Alternator Brackets w/ A/C #2230803
01/09/17 02:22 PM
01/09/17 02:22 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
In the attached photos of my 383, do the alternator brackets look right for having A/C? Did they use an idler in '70? I've never owned an A/C car, so this is all new to me.
Thanks!
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: 1970 Challenger 383 Alternator Brackets w/ A/C [Re: Erik] #2230836
01/09/17 03:20 PM
01/09/17 03:20 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The alternator brackets are 68 and older. Top and bottom 1970 brackets are different. The idler should be there and looks right. There are different thickness spacers behind it.
The AC compressor bracket look right, from the small part showing. It should bolt to the drivers side of the intake manifold only with a steel bracket. The cast iron 68 compressor bracket goes from drivers side to passenger side intake bolts.
Photo shows top of alt brackets 1970
Re: 1970 Challenger 383 Alternator Brackets w/ A/C [Re: Erik] #2231144
01/09/17 10:34 PM
01/09/17 10:34 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Alt brackets are not 70 and I see washers under the idler bracket. Cobbled together parts.
Re: 1970 Challenger 383 Alternator Brackets w/ A/C [Re: Erik] #2231271
01/10/17 12:37 AM
01/10/17 12:37 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The correct alt bracket goes behind the spacer on the idler. That will remove some of those washers you see.
Re: 1970 Challenger 383 Alternator Brackets w/ A/C [Re: Erik] #2231482
01/10/17 11:00 AM
01/10/17 11:00 AM
Mass
charge70 Offline
charge70  Offline
Mass
Erik,the pics that you posted look exactly like the 68 Chrysler Newport w/a 383 that I'm working on right now.Definatly not correct for a 70 E-body.I have a 440 w/ac out of a 70 Charger on the floor right now.I can snap pics if you want.Let me know. John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: 1970 Challenger 383 Alternator Brackets w/ A/C [Re: Erik] #2231503
01/10/17 11:48 AM
01/10/17 11:48 AM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
John - that would be great! Thanks!
Re: 1970 Challenger 383 Alternator Brackets w/ A/C [Re: Erik] #2231657
01/10/17 03:25 PM
01/10/17 03:25 PM
NJ
EV2RTSE Online content
EV2RTSE  Online Content
NJ
Here is a pic of my '70 383 w/ac, I believe everything is original on it.
Re: 1970 Challenger 383 Alternator Brackets w/ A/C [Re: Erik] #2231661
01/10/17 03:30 PM
01/10/17 03:30 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Excellent! Thanks!
Re: 1970 Challenger 383 Alternator Brackets w/ A/C [Re: Erik] #2231671
01/10/17 03:46 PM
01/10/17 03:46 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Yes it is correct 1970. Notice the bracket bolted to the front of th cylinder head for the alt pivot bolt on B engine only.
Re: 1970 Challenger 383 Alternator Brackets w/ A/C [Re: Erik] #2231964
01/10/17 11:46 PM
01/10/17 11:46 PM
Mass
charge70 Offline
charge70  Offline
Mass
Erik,do still need more pics or is that one enough? John.
Re: 1970 Challenger 383 Alternator Brackets w/ A/C [Re: Erik] #2232175
01/11/17 10:55 AM
01/11/17 10:55 AM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
John - Thanks, that one is enough.
