roller cam guys #223108
02/13/09 09:21 AM
02/13/09 09:21 AM
Gainesville, Fl
lildevil1972 Offline OP
Gainesville, Fl
Hey i was wondering if u guys could share with me what size roller cam u are running and what the valve spring pressure for a solid roller big block.
Re: roller cam guys [Re: lildevil1972] #223109
02/13/09 09:33 AM
02/13/09 09:33 AM
Indiana
79_W200 Offline
79_W200  Offline
Indiana
my springs measure 200 seat and 600 open cam is crower 270 int and 280 exh .700 lift
1979 W200 470
Re: roller cam guys [Re: 79_W200] #223110
02/13/09 09:43 AM
02/13/09 09:43 AM
Kentucky
sc301v Offline
sc301v  Offline
Kentucky
I am about 340 closed and 940 open.
I run a 815 800 lift
Re: roller cam guys [Re: lildevil1972] #223111
02/13/09 11:18 AM
02/13/09 11:18 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My isky solid roller runs 250+ on the seat and 550+ open w/ .680-.660 lift and 275-280 dur@ .050 and I drive this car a LOT on the street and race it a little when I can. Same cam, springs and lifters for 4+ years of trouble free performance.
Re: roller cam guys [Re: Thumperdart] #223112
02/13/09 12:01 PM
02/13/09 12:01 PM
Colorado
506RR Offline
506RR  Offline
Colorado
My spring pressures are 200 on the seat, and about 500 open with a Comp XR292R Street Solid Roller.
254/260 @ .050 and about .630 lift
Re: roller cam guys [Re: lildevil1972] #223113
02/13/09 12:35 PM
02/13/09 12:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I run a SB but that doesnt matter, its a .710 lift
but run it to 8200 rpm, using 320 seat and just over
900 open
Re: roller cam guys [Re: 506RR] #223114
02/13/09 12:37 PM
02/13/09 12:37 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Well this is purely for affect and well you asked...Mine are 370 on the seat and 1050 open Cam is 55MM roller lift is under .850"
Re: roller cam guys [Re: Al_Alguire] #223115
02/13/09 01:11 PM
02/13/09 01:11 PM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
My ...I was having issues with breaking valve spring after 80or so runs. They were comp 944's @1.95 height. Right around 200lbs seat as I recall. So per advice I switched to k-950 k-motions at the same installed height broke those too. I since then have looked at the removed pressure to find that they were at 160-170 when removed both the comps and k-motions. Last year I replaced them with another set of comp 944's . This time I paid more attention to the coil bind and seal bind measurements and set them up around 1.86 installed which was about 270lbs on the seat (newly installed) as I recall. I'm at work and don't have my paperwork handy. I haven't lost one since. This was on the 23-770-9 comp .690 roller.
Re: roller cam guys [Re: lildevil1972] #223116
02/13/09 01:45 PM
02/13/09 01:45 PM
AndyF Online content
AndyF  Online Content
In this round of dyno testing I was using a street roller cam and Comp 26094-16 springs.
http://www.moparmusclemagazine.com/techa...lock/index.html
For the next round of testing we stepped it up to a slightly bigger cam and Comp 26097-16 springs. The second combination hammered out 800 hp at 7000 rpm and the springs were really fairly basic duals.
Re: roller cam guys [Re: B1MAXX] #223117
02/13/09 01:46 PM
02/13/09 01:46 PM
I set mine up at 250 to 275 on the seats and end up with 630 to 650 lbs open at .730 lift at the retainers, Comp Cam lobes, springs and retainers and locks on a set of Eddy RPM heads,this combination is run a street motor that I shift at 7000+ RPM I put two years of racing on the first set and have near that on the second set, 100 or more runs per year and 300 to 600 street miles. I had been using the Mopar brand of solid rollers and had two lifter wheels break in two so I have switch to a set of Engle now Don't skimp on the springs or roller lifters
Re: roller cam guys [Re: Cab_Burge] #223118
02/13/09 02:34 PM
02/13/09 02:34 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Some roller lobes need more pressure than other, always get the recommended springs as the per the cam manufacturers recommendation. 557" RB Indy engine, comp custom solid roller with 285ish at 50. and .800+ lift with Jesel 1.7 rockers. I ran titanium retainers, PSI springs with about 300 seat, and 760 lbs open pressure. Spin it all day long to 7500+ rpm. has seen as high as 8K by accident
Re: roller cam guys [Re: lildevil1972] #223119
02/13/09 04:52 PM
02/13/09 04:52 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I was planning on running 250 pounds seat @ 2.000" install height and 710 pounds open @ 0.715" lift, but the 2.00" install height using +0.100" retainers and +0.050" locks are interfering with the rocker arms. If I go with standard locks the pressure goes up about 30 pounds.
Re: roller cam guys [Re: 451Mopar] #223120
02/13/09 05:14 PM
02/13/09 05:14 PM
Canada
RobR Offline
RobR  Offline
Canada
300 on the seat and 700 open for my GTX on the street...maybe 500-750 miles per set of springs.
