Re: roller cam guys
[Re: lildevil1972]
#223109
02/13/09 09:33 AM
02/13/09 09:33 AM
Posts: 317 Indiana
79_W200
Indiana
my springs measure 200 seat and 600 open cam is crower 270 int and 280 exh .700 lift
1979 W200 470
Re: roller cam guys
[Re: lildevil1972]
#223113
02/13/09 12:35 PM
02/13/09 12:35 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I run a SB but that doesnt matter, its a .710 lift but run it to 8200 rpm, using 320 seat and just over 900 open
Re: roller cam guys
[Re: 506RR]
#223114
02/13/09 12:37 PM
02/13/09 12:37 PM
Posts: 19,304 Las Vegas
Al_Alguire
Las Vegas
Well this is purely for affect and well you asked...Mine are 370 on the seat and 1050 open Cam is 55MM roller lift is under .850"
Re: roller cam guys
[Re: lildevil1972]
#223116
02/13/09 01:45 PM
02/13/09 01:45 PM
Posts: 30,947 Oregon
AndyF
In this round of dyno testing I was using a street roller cam and Comp 26094-16 springs. http://www.moparmusclemagazine.com/techa...lock/index.htmlFor the next round of testing we stepped it up to a slightly bigger cam and Comp 26097-16 springs. The second combination hammered out 800 hp at 7000 rpm and the springs were really fairly basic duals.
Re: roller cam guys
[Re: B1MAXX]
#223117
02/13/09 01:46 PM
02/13/09 01:46 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
I set mine up at 250 to 275 on the seats and end up with 630 to 650 lbs open at .730 lift at the retainers, Comp Cam lobes, springs and retainers and locks on a set of Eddy RPM heads,this combination is run a street motor that I shift at 7000+ RPM I put two years of racing on the first set and have near that on the second set, 100 or more runs per year and 300 to 600 street miles. I had been using the Mopar brand of solid rollers and had two lifter wheels break in two so I have switch to a set of Engle now Don't skimp on the springs or roller lifters
