Eagle vs Scat #2230178
01/08/17 06:14 PM
01/08/17 06:14 PM
North Carolina
Juicedrinker Offline OP
North Carolina
What's everyone's opinion on connecting rods between eagle and scat h beams for a 440 6.76 stock length and 1.094 stock pin ? About the same price and well known manufacturers same ratings and fasteners.
I’ll get it done one day....maybe....
Re: Eagle vs Scat [Re: Juicedrinker] #2230188
01/08/17 06:22 PM
01/08/17 06:22 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I had the opportunity to look at 5 different rods side by side and I chose K1 rods because they had the best fit and finish of all the other "offshore" rods I looked at twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Eagle vs Scat [Re: Juicedrinker] #2230194
01/08/17 06:30 PM
01/08/17 06:30 PM
North Carolina
North Carolina
Damn are eagle and scat made in China too?
Re: Eagle vs Scat [Re: Juicedrinker] #2230196
01/08/17 06:33 PM
01/08/17 06:33 PM
P
Porter67 Offline
Porter67  Offline
P
Ive learned that with good machine work a forged eagle crank and h beams will perform as well as the K1 products for what the majority do here.
I myself have had more trouble with K1 fitment then any other china assembly.
Re: Eagle vs Scat [Re: Porter67] #2230200
01/08/17 06:37 PM
01/08/17 06:37 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Molnar
'63 Dodge 330
11.19 @ 121 mph
Re: Eagle vs Scat [Re: Juicedrinker] #2230202
01/08/17 06:38 PM
01/08/17 06:38 PM
North Carolina
North Carolina
The only k1 rods I could find use a .990 pin so I can't use those anyway. Already have the Pistons that use stock 1.094 pins.
Re: Eagle vs Scat [Re: Juicedrinker] #2230215
01/08/17 06:51 PM
01/08/17 06:51 PM
P
Porter67 Offline
Porter67  Offline
P
You might glance on ebay, at times ive gotten new K1 H beams in the mopar pin for $300-350 at times when the norm is more like $600.
Re: Eagle vs Scat [Re: Juicedrinker] #2230224
01/08/17 06:55 PM
01/08/17 06:55 PM
North Carolina
North Carolina
Yeah I looked there all I found in those and the molnars was .990 pin around $650ish. If anybody comes across any let me know please
Re: Eagle vs Scat [Re: Juicedrinker] #2230226
01/08/17 06:57 PM
01/08/17 06:57 PM
P
Porter67 Offline
Porter67  Offline
P
Dont know what your building, but look at the scat I beams.
Re: Eagle vs Scat [Re: Juicedrinker] #2230242
01/08/17 07:12 PM
01/08/17 07:12 PM
pennsylvania
poboyengineering Offline
pennsylvania
My understanding is that all the rods and cranks in that price range are sourced from the same couple of foundries in China via AliBaba and the only real difference is the QC/finish machining. If anyone has info to the contrary, please feel free to chime in. I have no first hand knowledge, but that is what I've been led to believe.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Eagle vs Scat [Re: GY3] #2230249
01/08/17 07:16 PM
01/08/17 07:16 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Originally Posted By GY3
Molnar
100% the Molnar stuff is very nice. That's what I am running in my 499"
http://www.molnartechnologies.com/molnar-rods-domestic.html
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Eagle vs Scat [Re: Juicedrinker] #2230286
01/08/17 07:52 PM
01/08/17 07:52 PM
North Carolina
North Carolina
Well if anyone has a set or knows someone who does please let me know thanks
Re: Eagle vs Scat [Re: Juicedrinker] #2230300
01/08/17 07:59 PM
01/08/17 07:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I bought 4 sets of Eagle H-beams years ago when
they first started.. they are still running great
in my SB junk.. I have spun them way up a few times
(9600 rpm) but normal rpm is 8200 rpm... I dont know
how the quality is now days.. but guys are saying Scat
is better between Scat and Eagle... shruggy
wave
Re: Eagle vs Scat [Re: Juicedrinker] #2230326
01/08/17 08:29 PM
01/08/17 08:29 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Another vote for Molnar. Great customer service.
My son has a set in his small block 416 that made it through Hot Rod's Drag Week just fine and ran a 10.85 when he got back.
I have another set I am putting in a R-3 W-9 motor.
Bill
Re: Eagle vs Scat [Re: Juicedrinker] #2230336
01/08/17 08:35 PM
01/08/17 08:35 PM
crabman173
crabman173
ANY of the H beams you can get work fine I have run them all never a failure on any even the CAT --even the ones with the non ARP bolts have run great with zero issues on street strip style engines--I also moonlight at a shop[ that uses dozens of sets of the cheapest you can get NEVER a failure
You race--You have expensive heads--runs some eagles, Scats, Molners etc but you just play around with a street cheapo 500 In it does not matter they will all work great
Scat cranks are a PIA to balance compared to eagle FWIW
Re: Eagle vs Scat [Re: ] #2230533
01/09/17 12:43 AM
01/09/17 12:43 AM
dogdays Offline
dogdays  Offline
Eagle
K1
Molnar
Scat
Compstar
CAT
RPM
440Source
Star Galaxy
Any $500 rod
All Chinese forgings. And they probably came out of the same forging dies.
It's the finish machine work that is different.
The rough forgings I have seen on Ebay for less than $5.00 each.
R.
They are all plenty strong
Re: Eagle vs Scat [Re: dogdays] #2230539
01/09/17 12:49 AM
01/09/17 12:49 AM
North Carolina
North Carolina
Originally Posted By dogdays
Eagle
K1
Molnar
Scat
Compstar
CAT
RPM
440Source
Star Galaxy
Any $500 rod
R.
Damn that's crazy I didn't know they were all made in China. Oh well I guess whichever is the cheapest will work then.
Re: Eagle vs Scat [Re: Juicedrinker] #2230571
01/09/17 01:18 AM
01/09/17 01:18 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Having only to choose from eagle, or scat, I'd go with scat. I see the biggest difference between them in their cranks. Scat does better machine work than eagle. Scat kits always have more oil clearance than eagle. So that's why I'd pick Scat. Probably not any difference in strength.
Re: Eagle vs Scat [Re: dthemi] #2230583
01/09/17 01:42 AM
01/09/17 01:42 AM
North Carolina
North Carolina
Cool I've been leaning towards those anyway. I see a lot of mopar guys running scat stuff most of the time.
Re: Eagle vs Scat [Re: Juicedrinker] #2231177
01/09/17 11:02 PM
01/09/17 11:02 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Soooo, what con-rod is made in the U.S.A.?
