NAG1 controller option #2222462
12/28/16 10:18 PM
12/28/16 10:18 PM
tri-cities Washington/Denver, ...
5280Dart Offline OP
5280Dart  Offline OP
Tripped across this today... might be of interest to someone here looking at options for using the NAG1 transmission.
www.ofgear.dk
Re: NAG1 controller option [Re: 5280Dart] #2222528
12/29/16 12:16 AM
12/29/16 12:16 AM
USA
hudsonhornet7x Offline
USA
Cool, Thanks for sharing!
Re: NAG1 controller option [Re: 5280Dart] #2228573
01/06/17 01:44 PM
01/06/17 01:44 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
good Info!!! thank you
Re: NAG1 controller option [Re: 5280Dart] #2230182
01/08/17 06:15 PM
01/08/17 06:15 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
Nice, someone had to figure it out. The price isn't too bad considering all it does.
Re: NAG1 controller option [Re: 5280Dart] #2231028
01/09/17 07:51 PM
01/09/17 07:51 PM
GA
roadrunninMark Offline
GA
I must be missing it but I can't see the price????
Found it!
I've been talking with these guys about the NAG1....Sound German Automotive http://soundgermanautomotive.com/pcs/
Re: NAG1 controller option [Re: 5280Dart] #2231199
01/09/17 11:31 PM
01/09/17 11:31 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Looks like the PCS controller and harness is around $900. When you can find transmissionsome for $500-1000 I guess that's not TOO bad.
Mopar to the bone!!!
Re: NAG1 controller option [Re: 72Swinger] #2233753
01/13/17 09:56 PM
01/13/17 09:56 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Around here the trans go for $350-450. How much hp can these trans take?
Re: NAG1 controller option [Re: 5280Dart] #2233757
01/13/17 10:02 PM
01/13/17 10:02 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
How much? Couldn't find it.
Re: NAG1 controller option [Re: 5280Dart] #2233763
01/13/17 10:12 PM
01/13/17 10:12 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I found a used one for sale somewhere and the feller said he paid 9 bills new. These trans can take 1000rwhp in 4000lb cars when built up. Im guessing they could handle alot more in a 3000lb car.
Re: NAG1 controller option [Re: 5280Dart] #2233798
01/13/17 11:07 PM
01/13/17 11:07 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Stock I'm guessing 500ish? Plenty of modded 6.1's with stock tranny's. They actually came behind the 6.4's as well. Not sure what extra beef they had behind the 6.4's. I think the 5.7's and 6.1's used the same one
Re: NAG1 controller option [Re: 5280Dart] #2234116
01/14/17 06:21 PM
01/14/17 06:21 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
The 5.7's and SRT versions I know had different programming but I think they had different converters to. At any rate they all share the same foundation and can be built into a really stout trans that has really good lock up converters available. If I had a cool C-body I would love to see a 5.7 Hemi with a pair of 70mm turboes with one of these trans behind it and an 8 3/4 with some 3.23's, it would be a barrel of laughs.
Re: NAG1 controller option [Re: 5280Dart] #2234202
01/14/17 08:25 PM
01/14/17 08:25 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
What are the prices of the controllers?
Re: NAG1 controller option [Re: cudaman1969] #2235110
01/16/17 02:01 AM
01/16/17 02:01 AM
5280Dart Offline OP
5280Dart  Offline OP
PCS controller seems to list 1000-1500
Compushift says starting at 1034.00, but I believe I recently viewed a webpage listing more than double that price for the NAG1 variant.
I have not tracked down the price for the ofgear.dk unit.
Supposedly, Holley is working on including Nag1 support with their dominator efi system, but I have been unable to get anyone from the tech support line to answer the phone, and their web page does not currently list any such device. I have come across a couple others in the development phase, but no one seems to have this market segment covered at this time. I am going to muddle thru with a hotrod harness from hotwire automotive and the factory TCM for the time being.if it doesn't work well enough, or I kill the transmission, I will end up going with a 4l80E.
Re: NAG1 controller option [Re: 5280Dart] #2235111
01/16/17 02:04 AM
01/16/17 02:04 AM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
Where did you hear that from? I have the Dominator system but may ditch it so I can use the NAG.
Dennis
Re: NAG1 controller option [Re: cudaboy] #2235145
01/16/17 03:10 AM
01/16/17 03:10 AM
5280Dart Offline OP
5280Dart  Offline OP
Dennis
http://www.forbbodiesonly.com/moparforum/threads/5-7-nag1-swap-figured-out.88114/
Scroll down to a post by lxmodguy
Re: NAG1 controller option [Re: 5280Dart] #2235250
01/16/17 01:07 PM
01/16/17 01:07 PM
USA
USA
They have been discussing the Nag1- Holley setup for years with no results that I have seen yet- Don't hold your breath.
Re: NAG1 controller option [Re: 5280Dart] #2235263
01/16/17 01:20 PM
01/16/17 01:20 PM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
Dennis
Thanks.
Dennis
Re: NAG1 controller option [Re: hudsonhornet7x] #2235264
01/16/17 01:21 PM
01/16/17 01:21 PM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
I won't, I see that's from two years ago. I wish I knew someone at Holley to talk to, I live just a few miles from them.
Dennis
Re: NAG1 controller option [Re: 5280Dart] #2235592
01/16/17 09:14 PM
01/16/17 09:14 PM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
If a person can find a proven controller whats the fix for the lack of a slip yoke style output shaft? I have several Nag trannys that I'd like to retrofit but won't until these 2 issues are resolved. Anyone? Thanks
Re: NAG1 controller option [Re: J. Hammer] #2235733
01/17/17 12:26 AM
01/17/17 12:26 AM
5280Dart Offline OP
5280Dart  Offline OP
The Driveshaft Shop has a conversion flange that bolts to the NAG1 output flange, which then allows another flange, such as a 1350 ujoint flange. Then you have the rest of the driveshaft set up with a slip joint like a front shaft on a four wheel drive...I have an srt four finger flange on my nag1
http://www.driveshaftshop.com/domestic-d...-to-1350-flange
