Page 2 of 13 1 2 3 4 12 13
Re: 70 Road Runner resto [Re: 68Barracuda] #222791
02/15/09 07:42 PM
02/15/09 07:42 PM
MO
cdp Offline
cdp  Offline
MO
Nice work! Are you keeping it gold?
Re: 70 Road Runner resto [Re: cdp] #222792
02/15/09 09:21 PM
02/15/09 09:21 PM
Delaware shore
68Barracuda Offline OP
Delaware shore
NO, I'm leaning toward the 2006 Charger Go Mango
Re: 70 Road Runner resto [Re: 68Barracuda] #222793
02/15/09 09:47 PM
02/15/09 09:47 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
That's kind of bummer, the gold cars look great. And you would stand out in a sea of "popular" color cars.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: 70 Road Runner resto [Re: phantomx] #222794
02/26/09 06:14 PM
02/26/09 06:14 PM
Delaware shore
Delaware shore
Here are a couple of before pics of my steering column. It's my next subassembly rebuild. I'll post some after pics as I progress. Everything should clean up ok except for the wheel, it has some major cracks. If anyone has a decent one for sale shoot me a PM. I can repair some small cracks if need be.
Thanks,Rob
Re: 70 Road Runner resto [Re: 68Barracuda] #222795
02/26/09 06:15 PM
02/26/09 06:15 PM
Delaware shore
Delaware shore
#2
Re: 70 Road Runner resto [Re: 68Barracuda] #222796
02/27/09 08:53 PM
02/27/09 08:53 PM
Delaware shore
Delaware shore
We got some really nice weather here today, so I took advantage of it and started to sandblast the dash. When I brought it back in to blow it off I noticed what you see in the pic on the back side to the left of the steering column. Amazing it didn't blast off. anyone else ever notice this during a restore ? Seems it was a note to the paint shop. Just thought it might be of some interest.
Rob
Re: 70 Road Runner resto [Re: 68Barracuda] #222797
03/01/09 05:30 PM
03/01/09 05:30 PM
Delaware shore
Delaware shore
Here are some pics of the completed steering column. Go easy on me. I'm not a pro, just want to be done with the rust and grime. And be presentable when installed.
Re: 70 Road Runner resto [Re: 68Barracuda] #222798
03/01/09 05:33 PM
03/01/09 05:33 PM
Delaware shore
Delaware shore
next one
Re: 70 Road Runner resto [Re: 68Barracuda] #222799
03/01/09 05:34 PM
03/01/09 05:34 PM
Delaware shore
Delaware shore
3
Re: 70 Road Runner resto [Re: 68Barracuda] #222800
03/01/09 05:35 PM
03/01/09 05:35 PM
Delaware shore
Delaware shore
Re: 70 Road Runner resto [Re: 68Barracuda] #222801
03/01/09 05:35 PM
03/01/09 05:35 PM
Delaware shore
Delaware shore
Re: 70 Road Runner resto [Re: 68Barracuda] #222802
03/01/09 05:36 PM
03/01/09 05:36 PM
Delaware shore
Delaware shore
Re: 70 Road Runner resto [Re: 68Barracuda] #222803
03/01/09 05:37 PM
03/01/09 05:37 PM
Delaware shore
Delaware shore
Re: 70 Road Runner resto [Re: 68Barracuda] #222804
03/01/09 05:37 PM
03/01/09 05:37 PM
Delaware shore
Delaware shore
Last one
Re: 70 Road Runner resto [Re: 68Barracuda] #222805
03/02/09 08:46 PM
03/02/09 08:46 PM
Maine
itali83 Offline
itali83  Offline
Maine
Looks good, I just took mine apart for my '68. Started painting but will hopefully finish up next weekend. Did you have to buy anything parts wise for this column? I need to find a few trinkety things, like the little pointer for the gear indicator and a blinker switch. I know yours is a '70 and a little diffferent but where did you get parts if any? Thanks and keep up the good work. Doing the little things now will make it that much more enjoyable once everything comes together.
'68 Roadrunner Built 440/727 4:10 filled 8 3/4 in the process of a ground up restification
Re: 70 Road Runner resto [Re: itali83] #222806
03/02/09 09:16 PM
03/02/09 09:16 PM
MO
cdp Offline
cdp  Offline
MO
What did you use on the shaft? Polish, paint?
Looks real nice.
Re: 70 Road Runner resto [Re: cdp] #222807
03/02/09 10:28 PM
03/02/09 10:28 PM
Delaware shore
Delaware shore
I was lucky and didn't need to buy anything. But I have seen the switch you need on ebay. For the shaft I cleaned it, then sprayed it with Rust-oleum appliance epoxy (7887 stainless steel then cleared it.
Thanks,Rob
Re: 70 Road Runner resto [Re: 68Barracuda] #222808
03/05/09 01:01 PM
03/05/09 01:01 PM
Missouri
P
petty43 Offline
petty43  Offline
P
Missouri
I'm doing the same on my 68. To take the column apart do you take the dog leg on the engine side off or did you take the upper bearing off to take the steering wheel collar off?
I can't quite figure out which end need disassembled to take the column completely apart.
Nice work and clean car by the way.
1968 Satellite RR Copy Cat My Fleet
Re: 70 Road Runner resto [Re: petty43] #222809
03/05/09 04:55 PM
03/05/09 04:55 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Steering column looks nice Rob! I'm planning on doing mine this spring also.
65 Barracuda
70 Challenger
Re: 70 Road Runner resto [Re: petty43] #222810
03/06/09 12:32 AM
03/06/09 12:32 AM
Delaware shore
Delaware shore
You need to take the top apart. There is a snap ring and a c clip on the steel shaft. And you have to press the bearing off. There is a special tool but I didn't have one so I had to make up a jig with some c clamps. Be carefull the manual stresses several times do not hammer on it. Due to the plastic shear pins in the column. If you go to the mopar muscle web site. You may be able to find an article on one they did. It was pretty helpfull.
Good luck, Rob
