Re: Shaker Base Plate
[Re: amthoma]
#2227937
01/05/17 05:24 PM
01/05/17 05:24 PM
Posts: 10,141 A Red State
SNK-EYZ
A Red State
Probably more info will be needed for most to answer.
Engine, type of throttle bodies and throttle body spacing.
Just a guess, but if it's an RB engine then one that's designed for a Hemi for use with Edelbrock carbs with the larger air horn might be what you need.
[Re: SNK-EYZ]
#2227974
01/05/17 06:21 PM
01/05/17 06:21 PM
Posts: 4,569 Motor City
6PKRTSE
Motor City
I am looking for one also that I can modify for dual Dominator carbs for my Hemi. Steel or fiberglass would work for me since I will be cutting it up and trying to drop it some also.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: amthoma]
#2230362
01/08/17 09:04 PM
01/08/17 09:04 PM
Posts: 5,108 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
What someone will have to know is the center of one carb to the center of the other carb distance and if the carbs are inline or not. There is a Stage V intake with Eddys spread and a stock spread intake with stock carbs and there are base plates made for each spread in metal. Measure the spreads and the opening of you TBs. I will look up what the Stage V spread is and the stock spread. This will give you enough information to tell if a metal one can be used or you will have to buy a F.Glass base plate and modify it.
1971 HEMI E BODY REGISTRY
