Re: Dakota coil spring rate? PN interchange?upgrade springs
[Re: J. Hammer]
#2226974
01/04/17 09:52 AM
01/04/17 09:52 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
No idea on spring rates but I know it's been discussed before on various forums for the 97-04 trucks. Google may turn up something. The earlier trucks were a lot lighter though and may have a lighter rate. If the springs are the same diameter/height, simply swapping to a 97-04 spring may be all you need.
**Photobucket sucks**
[Re: J. Hammer]
#2227027
01/04/17 12:48 PM
01/04/17 12:48 PM
Posts: 300 MA
Greg55_99
MA
[Re: J. Hammer]
#2227637
01/05/17 10:10 AM
01/05/17 10:10 AM
70Cuda383
Marysville, O-H-I-O
Interesting. The end said that viper arms n spindles are close enough to Dakota that they can be used? What an easy way to run 13" rotors and 4 piston brembo calipers!
[Re: J. Hammer]
#2227752
01/05/17 01:53 PM
01/05/17 01:53 PM
Posts: 350 central IL
myduster360
central IL
Link states the FIRST Gen Vipers(92-96) share some Dakota parts and I knew they at least used the exact same UCA but then they show picks of a SECOND Gen Viper(96-02) suspension!?!?
Knuckles and LCA look completely different Gen1 vs Gen2 Viper
1972 Swinger 3.6L Pentastar Diablo CMR tuner
[Re: J. Hammer]
#2227786
01/05/17 02:31 PM
01/05/17 02:31 PM
70Cuda383
Marysville, O-H-I-O
I don't know the vipers well enough, do the gen 1 and 2 cars have the same front suspension? They use the same brakes, and the pics in the link appear to have the gen 1-2 caliper mount ears vs the gen 3 cars that use a radial mount caliper
I didn't know they had the same exact upper control arm dimensions as Dakota, which years Dakota? The pics look like cast aluminum arms. The 97-04 dakotas use a stamped steel control arm
[Re: J. Hammer]
#2227878
01/05/17 03:51 PM
01/05/17 03:51 PM
70Cuda383
Marysville, O-H-I-O
Is that ball joint riveted in? It certainly looks similar. Definitely different than the pics in the link above.
[Re: J. Hammer]
#2227928
01/05/17 05:03 PM
01/05/17 05:03 PM
myduster360
central IL
No it looks like it screws in.
