does the ratech dana 60 pinion depth tool work to set depth? #2225118
01/01/17 10:38 PM
01/01/17 10:38 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
looking at the ratech 10009 dana 60 pinion depth tool,im starting from scratch so i have no old shims to go off,the pinion is marked +1.i will be using the splash piece under the pinion bearing and the baffle with a shim under the race cup in the housing.rear is a dana 60hd housing installing 4.10 factory gears.thanks for any info.
Re: does the ratech dana 60 pinion depth tool work to set depth? [Re: hp340nos] #2225275
01/02/17 01:34 AM
01/02/17 01:34 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I used one when I set up my used 4.56 gear set. Actually checked my 4.30 gears before I removed them and it was within .0002 of where they were installed. A newer gear set with the depth inscribed on it makes the install much easier with that particular tool as you can see with their instructions:
http://www.ratechmfg.com/pinion%20setting%20tool.htm
Re: does the ratech dana 60 pinion depth tool work to set depth? [Re: J_BODY] #2225537
01/02/17 01:53 PM
01/02/17 01:53 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
ok sounds good,i will get the tool.im just looking for something to get a reference to start with,to get me in the ball park,i have no old shims to start with .rear housing is a dana hd60.thanks mike
Re: does the ratech dana 60 pinion depth tool work to set depth? [Re: hp340nos] #2226542
01/03/17 08:13 PM
01/03/17 08:13 PM
San Diego, USA
SoCalRacer Offline
SoCalRacer  Offline
San Diego, USA
If you have no shims it will take a few tries to get the pinion depth right. Aftermarket gearsets have the pinion depth marked on them, for example 3.127, which would be +.002 (or .002 less shims) from the designed ideal depth of 3.125. Since you have none, a good starting point on shims is .035"
If it ain't broke ... you're not pushing it hard enough.
Re: does the ratech dana 60 pinion depth tool work to set depth? [Re: hp340nos] #2226657
01/03/17 10:32 PM
01/03/17 10:32 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Do yourself a huge favor and make or buy some setup bearings before you start the build twocents
I use setup bearings on just about every rear I do now except 9" rears,somebody was thinking about the technician whey designed that carrier.
Gus beer
64 Plymouth Savoy
Dana 60
Re: does the ratech dana 60 pinion depth tool work to set depth? [Re: hp340nos] #2226732
01/03/17 11:32 PM
01/03/17 11:32 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
well mine is a S60 so it's like hitting the easy button compared to a regular D60 smile Side adjusters for the win!
I also prefer to put the shim under the bearing race for ease of making changes.
Re: does the ratech dana 60 pinion depth tool work to set depth? [Re: J_BODY] #2226808
01/04/17 12:31 AM
01/04/17 12:31 AM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
yes im using going to be using the set up bearings.thanks for the info.i have a baffle .020 +.025 in shims under the bearing race=.045 and the splash shield between the pinion head and rear pinion bearing is .030.to start with.
Re: does the ratech dana 60 pinion depth tool work to set depth? [Re: hp340nos] #2226976
01/04/17 09:55 AM
01/04/17 09:55 AM
Brisbane Australia
crash520 Offline
crash520  Offline
Brisbane Australia
Dont want to hijack the thread but the baffle and splash shields that come with the bearing shim kits, where do they go and do they need to be installed?? My D60 was out of an F250 rear and didnt have any of them installed, just the shim packs under the bearings per normal
