Re: does the ratech dana 60 pinion depth tool work to set depth?
[Re: J_BODY]
#2225537
01/02/17 01:53 PM
01/02/17 01:53 PM
Posts: 1,365 elmira ny
hp340nos
elmira ny
ok sounds good,i will get the tool.im just looking for something to get a reference to start with,to get me in the ball park,i have no old shims to start with .rear housing is a dana hd60.thanks mike
[Re: hp340nos]
#2226542
01/03/17 08:13 PM
01/03/17 08:13 PM
Posts: 51 San Diego, USA
SoCalRacer
San Diego, USA
If you have no shims it will take a few tries to get the pinion depth right. Aftermarket gearsets have the pinion depth marked on them, for example 3.127, which would be +.002 (or .002 less shims) from the designed ideal depth of 3.125. Since you have none, a good starting point on shims is .035"
If it ain't broke ... you're not pushing it hard enough.
[Re: hp340nos]
#2226657
01/03/17 10:32 PM
01/03/17 10:32 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Do yourself a huge favor and make or buy some setup bearings before you start the build I use setup bearings on just about every rear I do now except 9" rears,somebody was thinking about the technician whey designed that carrier. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: hp340nos]
#2226732
01/03/17 11:32 PM
01/03/17 11:32 PM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
well mine is a S60 so it's like hitting the easy button compared to a regular D60 Side adjusters for the win! I also prefer to put the shim under the bearing race for ease of making changes.
