Ultradyne cam question #2226073
01/03/17 01:09 AM
01/03/17 01:09 AM
CA.
RAY1969CARS Offline OP
CA.
I have never heard of this cam company and I do have a cam card as you can see in the picture but could someone please break down how good or not good this cam is
Re: Ultradyne cam question [Re: RAY1969CARS] #2226082
01/03/17 01:17 AM
01/03/17 01:17 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Ultradyne made some very good stuff. That looks like the '68 340 stick cam.. Also a very good peice.
Re: Ultradyne cam question [Re: RAY1969CARS] #2226115
01/03/17 02:25 AM
01/03/17 02:25 AM
GA
roadrunninMark Online sick
roadrunninMark  Online Sick
GA
Ultradyne has made my cam as well. I hope to have the engine running this year. My engine guy really likes Ultradyne and uses them in his builds; including his own.
Re: Ultradyne cam question [Re: RAY1969CARS] #2226135
01/03/17 03:00 AM
01/03/17 03:00 AM
Ultradyne and Bullett cams are in the same building, I'm not sure what the exact reasons are, but both grind decent Mopar cams. What motor and intended use are you thinking of using this cam in?
As already pointed out it is not a race cam or a very big cam for street use shruggy
Re: Ultradyne cam question [Re: Cab_Burge] #2226137
01/03/17 03:05 AM
01/03/17 03:05 AM
CA.
CA.
A mild 1971 360 bolt ons only intake carb and headers in a 69 dart for speed if it's not the right fit for me I'm going. Sell it got it I got it new in a deal with other parts
Re: Ultradyne cam question [Re: Cab_Burge] #2226140
01/03/17 03:09 AM
01/03/17 03:09 AM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
Ultradyne closed some years ago,Bullet and Lunati cams can grind these lobes.I use Bullet but I am less than 15 mnutes from Comp/Lunati and Bullet cams. The cam card the op posted is at least 20 years old but the grind should work fine in the right mild application.
Re: Ultradyne cam question [Re: RAY1969CARS] #2226345
01/03/17 03:16 PM
01/03/17 03:16 PM
I
Interceptor72 Offline
I
Ultradyne, and the guy who designed those lobes (Harold Brookshire), are legendary.
He also designed the Comp XE and Lunati Voodoo lines of cams, which are some of the best ever 'off the shelf' grinds (in their day.)
BUT, I believe most of the Ultradyne cams were custom...which means custom for somebody else's setup, not yours. And this would be a very old grind by now. I believe they've been out of business for decades. So a modern grind from the Lunati Voodoo line (designed by the same guy, but perhaps 10 years newer design) would probably be better.
However, for the right application, that probably would have been one of the best cams you could have bought (just because of who designed it)...20 years ago.
Re: Ultradyne cam question [Re: Interceptor72] #2226354
01/03/17 03:24 PM
01/03/17 03:24 PM
CA.
CA.
Do you think it's worth anything ??
Re: Ultradyne cam question [Re: RAY1969CARS] #2226365
01/03/17 03:37 PM
01/03/17 03:37 PM
I
I
You mean like on Ebay?
Maybe, if the right guy sees it, knows what they are looking at, and thinks it would work for him.
If you mean for your own use, you could probably do a lot worse...especially since it's already paid for. But you could also do a lot better if you want to spend the money.
It depends on what you want to pay vs what you want to achieve. Some people love to see how much they can achieve with what they have on hand. In this case, I would definitely use it.
Some people want to spend as much as it takes to get the best possible results (within reason.) Those people would probably order a new custom cam from Bullet, Jones Cams or the company of their choice.
Re: Ultradyne cam question [Re: Interceptor72] #2226383
01/03/17 04:01 PM
01/03/17 04:01 PM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
Harold designed cams for many cam companies,but he would roll over in his grave to be linked to the Comp XE series grinds. He did design the early High energy grinds for Comp that put Comp on the map.
Re: Ultradyne cam question [Re: RAY1969CARS] #2226411
01/03/17 04:57 PM
01/03/17 04:57 PM
an8sec70cuda Offline
Ultradyne made some good stuff. They went out of business and one guy went to Lunati and the other went to Bullet cams. Harold Brookshire and Tim Goolsby are the two fellas I'm referring to, just can't remember which went where.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Ultradyne cam question [Re: an8sec70cuda] #2226424
01/03/17 05:18 PM
01/03/17 05:18 PM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
Tims at Bullet,Steves at Lunati.
Re: Ultradyne cam question [Re: J. Hammer] #2226430
01/03/17 05:22 PM
01/03/17 05:22 PM
I
I
Sorry, HE not XE
Got my acronyms mixed up.
Re: Ultradyne cam question [Re: RAY1969CARS] #2226522
01/03/17 07:39 PM
01/03/17 07:39 PM
People's Republic of Mass.
Belvedere2 Offline
Belvedere2  Offline
I wouldn't be afraid to run it in a stockish 360. Stock iron heads I assume. Just give it some compression in the 9s and go for it.
Re: Ultradyne cam question [Re: RAY1969CARS] #2226551
01/03/17 08:28 PM
01/03/17 08:28 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Not worth much IMO. Its basically a torque cam, that's just abit better then stock. Think RV/truck cam. Its very mild with not a lot of lift. I do like the 110 LSA though.
If its for the 360, id go bigger, more like 220 @ .050 and 480 lift or so if you want more power but still be a mild cam.
Does it come with the lifters? I myself see nobody really wanting that cam. Maybe a 318 guy though... shruggy
Re: Ultradyne cam question [Re: Interceptor72] #2226606
01/03/17 09:34 PM
01/03/17 09:34 PM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
Sorry, HE not XE
LOL No harm but knowing Harold for many years I guess should mention it.
Re: Ultradyne cam question [Re: RAY1969CARS] #2226797
01/04/17 12:19 AM
01/04/17 12:19 AM
A727Tflite Offline
A727Tflite  Offline
So if I read this correctly - Harold passed away? I first met him when he worked at General Kinetics - him and Don Teweles had the best stuff out there - way ahead of the time.
Re: Ultradyne cam question [Re: A727Tflite] #2226803
01/04/17 12:25 AM
01/04/17 12:25 AM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
Yep Harold passed away and yes he did some GK lobes in the 70's.Kinda funny story,I was in Bullet picking up parts last week and talking to a good friend and another cam companys owner called and had an Ultradyne cam ordered for his personal mopar powered ride. Doesn't suprise me much.
Re: Ultradyne cam question [Re: RAY1969CARS] #2226822
01/04/17 12:47 AM
01/04/17 12:47 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Ultradyne used to be the place you went to when you wanted the best cam money could buy. Their stuff was more expensive than Crane, etc., but it was worth it.
Re: Ultradyne cam question [Re: slantzilla] #2226849
01/04/17 01:20 AM
01/04/17 01:20 AM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
I used to call in the AM and drive by and pick my cam up on the way home from work.
