Re: Ultradyne cam question
[Re: RAY1969CARS]
#2226082
01/03/17 01:17 AM
01/03/17 01:17 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Ultradyne made some very good stuff. That looks like the '68 340 stick cam.. Also a very good peice.
[Re: RAY1969CARS]
#2226135
01/03/17 03:00 AM
01/03/17 03:00 AM
Posts: 43,230 Bend,OR USA
Cab_Burge
Ultradyne and Bullett cams are in the same building, I'm not sure what the exact reasons are, but both grind decent Mopar cams. What motor and intended use are you thinking of using this cam in? As already pointed out it is not a race cam or a very big cam for street use
[Re: Cab_Burge]
#2226137
01/03/17 03:05 AM
01/03/17 03:05 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
A mild 1971 360 bolt ons only intake carb and headers in a 69 dart for speed if it's not the right fit for me I'm going. Sell it got it I got it new in a deal with other parts
[Re: RAY1969CARS]
#2226345
01/03/17 03:16 PM
01/03/17 03:16 PM
Posts: 76 Florida
Interceptor72
Ultradyne, and the guy who designed those lobes (Harold Brookshire), are legendary. He also designed the Comp XE and Lunati Voodoo lines of cams, which are some of the best ever 'off the shelf' grinds (in their day.) BUT, I believe most of the Ultradyne cams were custom...which means custom for somebody else's setup, not yours. And this would be a very old grind by now. I believe they've been out of business for decades. So a modern grind from the Lunati Voodoo line (designed by the same guy, but perhaps 10 years newer design) would probably be better. However, for the right application, that probably would have been one of the best cams you could have bought (just because of who designed it)...20 years ago.
[Re: Interceptor72]
#2226354
01/03/17 03:24 PM
01/03/17 03:24 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
Ultradyne, and the guy who designed those lobes (Harold Brookshire), are legendary. He also designed the Comp XE and Lunati Voodoo lines of cams, which are some of the best ever 'off the shelf' grinds (in their day.) BUT, I believe most of the Ultradyne cams were custom...which means custom for somebody else's setup, not yours. And this would be a very old grind by now. I believe they've been out of business for decades. So a modern grind from the Lunati Voodoo line (designed by the same guy, but perhaps 10 years newer design) would probably be better. However, for the right application, that probably would have been one of the best cams you could have bought (just because of who designed it)...20 years ago. Do you think it's worth anything ??
[Re: RAY1969CARS]
#2226411
01/03/17 04:57 PM
01/03/17 04:57 PM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
Ultradyne made some good stuff. They went out of business and one guy went to Lunati and the other went to Bullet cams. Harold Brookshire and Tim Goolsby are the two fellas I'm referring to, just can't remember which went where.
[Re: RAY1969CARS]
#2226551
01/03/17 08:28 PM
01/03/17 08:28 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Not worth much IMO. Its basically a torque cam, that's just abit better then stock. Think RV/truck cam. Its very mild with not a lot of lift. I do like the 110 LSA though. If its for the 360, id go bigger, more like 220 @ .050 and 480 lift or so if you want more power but still be a mild cam. Does it come with the lifters? I myself see nobody really wanting that cam. Maybe a 318 guy though...
[Re: Interceptor72]
#2226606
01/03/17 09:34 PM
01/03/17 09:34 PM
Posts: 184 Memphis,TN
J. Hammer
Memphis,TN
Sorry, HE not XE Got my acronyms mixed up. LOL No harm but knowing Harold for many years I guess should mention it.
[Re: RAY1969CARS]
#2226822
01/04/17 12:47 AM
01/04/17 12:47 AM
Posts: 20,188 Park Forest, IL
slantzilla
Park Forest, IL
Ultradyne used to be the place you went to when you wanted the best cam money could buy. Their stuff was more expensive than Crane, etc., but it was worth it.
