is this the correct master cylinder? #2225114
01/01/17 10:29 PM
01/01/17 10:29 PM
omahell, ne
buconine Offline OP
buconine  Offline OP
omahell, ne
Working on my late fathers 70 challenger. The master cyl is leaking fluid inside the car. When looking at replacement masters all the ones that look like the one on the car are listed as power 4 wheel drum. The car is a manual 4 wheel drum. I remember my dad putting a master on the car a long time ago, possible he got the wrong one? I was going to rebuild it if correct, replace if not. Thanks for any info.
Re: is this the correct master cylinder? [Re: buconine] #2225190
01/02/17 12:00 AM
01/02/17 12:00 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
That looks like the right one for drum brakes.
Cast in the bottom of it if it is correct will either be 2225001, 2660909, nothing or AANF
Re: is this the correct master cylinder? [Re: buconine] #2225219
01/02/17 12:38 AM
01/02/17 12:38 AM
omahell, ne
buconine Offline OP
buconine  Offline OP
omahell, ne
do power and manual drums use the same master? Thanks for the info. Can't read the bottom of the master. i'll have to pull it off and clean it up
Re: is this the correct master cylinder? [Re: buconine] #2225269
01/02/17 01:28 AM
01/02/17 01:28 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I'm pretty sure they are the same but Mastershake340 is our resident expert.
The one you have is the same as what is on my manual drum brake 70 Hemi GTX
Re: is this the correct master cylinder? [Re: Morty426] #2225319
01/02/17 02:19 AM
01/02/17 02:19 AM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
Looks correct to me. 2225601 is one of the correct casting numbers.
The only difference between manual and power drum master cylinders is the manual version has a dust boot installed on the flange at the bore.
Re: is this the correct master cylinder? [Re: buconine] #2225431
01/02/17 11:35 AM
01/02/17 11:35 AM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
Not correct for power disc.
Re: is this the correct master cylinder? [Re: magiccuda] #2225550
01/02/17 02:04 PM
01/02/17 02:04 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
His question was whether it was correct for power drums
Re: is this the correct master cylinder? [Re: buconine] #2226014
01/03/17 12:19 AM
01/03/17 12:19 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Power brakes will often have a larger internal cylinder than will manual. You probably should get it correct for your car before buying a new one.
Small cylinder equal more brake shoe pressure, longer pedal throw. Larger cylinder equal less brake shoe pressure with shorter brake pedal throw,,,,braking pressure is enhanced by power brake booster.
Re: is this the correct master cylinder? [Re: Sxrxrnr] #2226084
01/03/17 01:18 AM
01/03/17 01:18 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Definitely the correct 4 wheel drum master. All the Cardone and other rebuilders that you buy at the typical parts stores are completely wrong, please rebuild the one you have! wave
JB Rhinehart, Realist
A-Body's RULE!
Re: is this the correct master cylinder? [Re: buconine] #2226155
01/03/17 05:09 AM
01/03/17 05:09 AM
WA
tman Offline
tman  Offline
WA
Service manual specs shows 1" bore MC for drum brake applications whether 6cyl or V-8 & HD. Disc brake setup has 1 1/8" MC bore.
For drum brakes there is no mention if its used for power or manual. Here is a quote from the Service Manual. "The MC used on vehicles not equipped with power brake units is serviced in the same manner as the MC with power brakes, with one exception, the MC for power brakes does not include the push rod." Hope this helps.
Re: is this the correct master cylinder? [Re: tman] #2226214
01/03/17 12:01 PM
01/03/17 12:01 PM
Crook County, ILL
Crook County, ILL
'70 E body disc brake master cylinder was 1" bore also, for all engines except hemi. Disc brake hemi E bodies were the only cars that got a 1-1/8"
Re: is this the correct master cylinder? [Re: buconine] #2226794
01/04/17 12:17 AM
01/04/17 12:17 AM
omahell, ne
buconine Offline OP
buconine  Offline OP
omahell, ne
thanks for the info! I'll get my kit ordered so i can at least have brakes again.
Re: is this the correct master cylinder? [Re: buconine] #2227288
01/04/17 07:38 PM
01/04/17 07:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Good luck, hopefully the bore is not pitted to badly that replacement seals don't stop the leaking.
Re: is this the correct master cylinder? [Re: buconine] #2227726
01/05/17 01:28 PM
01/05/17 01:28 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Brakes are good
Re: is this the correct master cylinder? [Re: JohnRR] #2227760
01/05/17 02:04 PM
01/05/17 02:04 PM
Crook County, ILL
Crook County, ILL
If it ends up leaking after rebuild, send it up to Brake and Equipment warehouse for a sleeve.
Re: is this the correct master cylinder? [Re: tman] #2228372
01/06/17 01:55 AM
01/06/17 01:55 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Table of 1970 Master cylinder applications
http://www.imperialclub.org/Repair/Lit/Master/274/page13.htm
Re: is this the correct master cylinder? [Re: buconine] #2237555
01/19/17 10:55 PM
01/19/17 10:55 PM
omahell, ne
buconine Offline OP
buconine  Offline OP
omahell, ne
You guys called it. Even after a good hone the bore is so pitted that i'm not even going to try an install the kit. The holes in master leading to the bore are clogged and the whole thing is full of sludge and rust. Tried oreillys, napa, carquest, etc and they all have the wrong master. I'll have to look into getting it sleeved. It is casting #2225601. Thanks!!
Re: is this the correct master cylinder? [Re: buconine] #2237598
01/19/17 11:50 PM
01/19/17 11:50 PM
Banana Republic
FM3AAR Offline
FM3AAR  Offline
Banana Republic
Per Mastershake's recommendation, I shipped my m/c off today to Brake and Equipment Warehouse to be sleeved.
“You’ll own nothing” — And “you’ll be happy about it.”
K. Schwab
Re: is this the correct master cylinder? [Re: buconine] #2237642
01/20/17 12:44 AM
01/20/17 12:44 AM
omahell, ne
buconine Offline OP
buconine  Offline OP
omahell, ne
calling myself in the morning. Do they overhaul it as well or just sleeve?
Re: is this the correct master cylinder? [Re: buconine] #2237659
01/20/17 12:59 AM
01/20/17 12:59 AM
Crook County, ILL
Crook County, ILL
They will just sleeve, or can rebuild it also for you.
