Re: is this the correct master cylinder?
[Re: magiccuda]
#2225550
01/02/17 02:04 PM
01/02/17 02:04 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Not correct for power disc. His question was whether it was correct for power drums
[Re: buconine]
#2227288
01/04/17 07:38 PM
01/04/17 07:38 PM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
thanks for the info! I'll get my kit ordered so i can at least have brakes again. Good luck, hopefully the bore is not pitted to badly that replacement seals don't stop the leaking.
[Re: buconine]
#2227726
01/05/17 01:28 PM
01/05/17 01:28 PM
Morty426
Sacramento CA
thanks for the info! I'll get my kit ordered so i can at least have brakes again. Brakes are good
[Re: JohnRR]
#2227760
01/05/17 02:04 PM
01/05/17 02:04 PM
Posts: 8,341 Crook County, ILL
Mastershake340
Crook County, ILL
thanks for the info! I'll get my kit ordered so i can at least have brakes again. Good luck, hopefully the bore is not pitted to badly that replacement seals don't stop the leaking. If it ends up leaking after rebuild, send it up to Brake and Equipment warehouse for a sleeve.
[Re: buconine]
#2237598
01/19/17 11:50 PM
01/19/17 11:50 PM
Posts: 2,344 Banana Republic
FM3AAR
Banana Republic
Per Mastershake's recommendation, I shipped my m/c off today to Brake and Equipment Warehouse to be sleeved.
“You’ll own nothing” — And “you’ll be happy about it.” K. Schwab
