E-heads and stock 340 hp manifolds
#2223880
12/31/16 05:07 AM
12/31/16 05:07 AM
70duster340
Has anyone else had this problem? I seem to have a clearance issue on the passenger side. If I use a header flange, I have a clearance problem with the TTI pipes. I really need the help here.
TIA!!!
Re: E-heads and stock 340 hp manifolds
[Re: 70duster340]
#2223935
12/31/16 11:46 AM
12/31/16 11:46 AM
RapidRobert
the pass mani wont directly bolt on the E heads? (what part is off or hitting) & if you use a header flange for a spacer so it will bolt on then that wont let the TTI pipes fit up to the mani outlet flange?
[Re: 70duster340]
#2224299
12/31/16 09:19 PM
12/31/16 09:19 PM
70duster340
[Re: 70duster340]
#2224644
01/01/17 12:49 PM
01/01/17 12:49 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
What is the block? IIRC 5.2 and 5.9 magnum blocks have a protrusion in that same area that must be ground down with a lot of exhaust types.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: 70duster340]
#2225284
01/02/17 01:44 AM
01/02/17 01:44 AM
70duster340
[Re: 70duster340]
#2226152
01/03/17 04:15 AM
01/03/17 04:15 AM
70duster340
