E-heads and stock 340 hp manifolds #2223880
12/31/16 05:07 AM
12/31/16 05:07 AM
70duster340 Offline OP
Has anyone else had this problem? I seem to have a clearance issue on the passenger side. If I use a header flange, I have a clearance problem with the TTI pipes. I really need the help here.
TIA!!!
Re: E-heads and stock 340 hp manifolds [Re: 70duster340] #2223935
12/31/16 11:46 AM
12/31/16 11:46 AM
the pass mani wont directly bolt on the E heads? (what part is off or hitting) & if you use a header flange for a spacer so it will bolt on then that wont let the TTI pipes fit up to the mani outlet flange?
Re: E-heads and stock 340 hp manifolds [Re: 70duster340] #2224113
12/31/16 04:44 PM
12/31/16 04:44 PM
My mistake, I should have said the driver's side manifold. It's the portion of the manifold above the exhaust pipe flange where the manifold curves. It sets against the block and won't contact the exhaust port area. With the tight fit of the TTI's adding the 3/8 header flange causes interference. Any suggestions or ideas?
Re: E-heads and stock 340 hp manifolds [Re: 70duster340] #2224299
12/31/16 09:19 PM
12/31/16 09:19 PM
BTT
Re: E-heads and stock 340 hp manifolds [Re: 70duster340] #2224644
01/01/17 12:49 PM
01/01/17 12:49 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
What is the block? IIRC 5.2 and 5.9 magnum blocks have a protrusion in that same area that must be ground down with a lot of exhaust types.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: E-heads and stock 340 hp manifolds [Re: 70duster340] #2224843
01/01/17 04:11 PM
01/01/17 04:11 PM
It's a 71 340 with E-heads.
Re: E-heads and stock 340 hp manifolds [Re: 70duster340] #2225284
01/02/17 01:44 AM
01/02/17 01:44 AM
BTT
Re: E-heads and stock 340 hp manifolds [Re: 70duster340] #2226152
01/03/17 04:15 AM
01/03/17 04:15 AM
BTT once more
Re: E-heads and stock 340 hp manifolds [Re: 70duster340] #2226178
01/03/17 09:22 AM
01/03/17 09:22 AM
BDW Online content
BDW  Online Content
Post a couple of pics
