TRW 2266 Pistons (ring choice)-Boost Build??? Ring Advice
#2225846
01/02/17 08:45 PM
01/02/17 08:45 PM
Posts: 1,549 DC, MD Suburbs
440PURSUIT
DC, MD Suburbs
I have a steel crank short block with LY rods. Quality machine work and Balanced. Its kinda like a balanced New Yorker replacement build short block.
Its not worth using up Indy or Victor heads I have in Aluminum to make compression with a 5900 shift point engine in am available a or b body.
I'm thinking about a Turbo build with small Garrett twins.
Will this piston design (5/64 ring) be ok to build to 15psi? if so, should I call CP to replace the moly rings I used.
I see their modern Coated Stainless rings are a better choice. Im unsure if 5/64 top and bottom are available for such an application.
Pistons are .060 down. While on the subject, would a 906 Wedge head at 88cc (8.8:1 CR) or a 516 at 78cc (9.8 CR) work better considering quench.
Trying to do this in a 72 Charger Street Car..
Thanks in advance!
1969 Hemi Charger R/T, 1970 Charger 472 Hemi 6 Sp 1969 Charger Pro Tour Project 1971 Barracuda Convert 1970 440 6pack Superbird, 1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue) 1967 Barracuda Convert 1968 Barracuda Coupe 1972 Charger w 383 1972 Sebring Plus 440-6 Clone 1969 Coronet Pro Street 2009 Challengeer SRT8 stick 1992-1986 Body 2500 4x4 440 stick 1982 Ramcharger 318 Sniper- getting enhanced. 1997 Ram B3500 Van 5.9 1991.5 W250 Cummins- Big Chief
Re: TRW 2266 Pistons (ring choice)-Boost Build??? Ring Advice
[Re: 440PURSUIT]
#2225855
01/02/17 08:56 PM
01/02/17 08:56 PM
Posts: 14,502 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
One of the big problems with the trw OE replacement style pistons in higher hp applications is the poor wrist pin oiling situation. They will often gall up the pin bores if you make decent power or turn a lot of rpm.
[Re: 440PURSUIT]
#2225863
01/02/17 09:04 PM
01/02/17 09:04 PM
440PURSUIT
DC, MD Suburbs
Hi Duane, Thanks for the reply. Intend to keep it below 6000 rpm with a 323 gear.
[Re: 440PURSUIT]
#2225865
01/02/17 09:07 PM
01/02/17 09:07 PM
fast68plymouth
So. Burlington, Vt.
I assume with boost it will make enough power so this would still be a concern.
IMO, just not really the right part for the job, although I'm sure many will disagree.
As they say....."your results may vary".
