Re: 1970 Cuda disc brake conversion question
[Re: biginchmotor]
#2223711
12/30/16 11:46 PM
12/30/16 11:46 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Drums or discs on the rear? Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: biginchmotor]
#2223721
12/30/16 11:53 PM
12/30/16 11:53 PM
Posts: 8,135 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
I think this is later than you are requesting but it's a start
[Re: biginchmotor]
#2223751
12/31/16 12:36 AM
12/31/16 12:36 AM
Posts: 18,157 Mass
DAYCLONA
Mass
A friend is changing over his front drums to disc brakes on his 70 cuda. I see inline tube sells the proper valve to do this. Would someone have a reference picture of this valve mounted on the car? Also there is another hold off valve shown in their product picture. How does this valve mount? The picture shows this small valve but I do not see a mounting bracket. Thanks John. I avoid the In-Line brand proportioning valve (PV) has too many issues from leaks to non functioning, to stuck valve assys, buy the one from FINELINES here's a few photos
[Re: DAYCLONA]
#2223759
12/31/16 12:47 AM
12/31/16 12:47 AM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: biginchmotor]
#2224138
12/31/16 05:24 PM
12/31/16 05:24 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Thanks for posting those pictures dayclona. I went to fine lines web site and could not find that part #. I will give them a call Tuesday morning. John. IIRC FINELINES uses the same PN# as IN-LINE TUBE, part is from the same oversea vendor (China repro) but FINELINES disassembles and rebuilds/tests the unit prior to shipping to customer because of the known issues with this valve, IN-Line Tube just repackages it for resale mike
[Re: AARCONV]
#2225590
01/02/17 02:54 PM
01/02/17 02:54 PM
Posts: 1,567 Ky
jt4406
Ky
the rear proportional valve bolts into the frame in the same spot that the reverse lock out z-bar bracket attaches to I think? that picture I would like to see if anyone has that combination AARConv, I believe the valve bolts on farther back than the lockout linkage. In this pic of my car you can see the tapped bolt holes for the linkage bracket ahead of the valve. jess
Yeah, it's hopped up to over 160...
